跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Lenovo W600 Keyboard,请使用我们的维修手册
  1. Lenovo W600 Keyboard Teardown, Removing the backplate: 步骤 1 中的图像 1,2 Lenovo W600 Keyboard Teardown, Removing the backplate: 步骤 1 中的图像 2,2
    • Take off the protective stickers on the four corners
    • Use a Phillips screwdriver to remove all five screws on the keyboard
    • Insert a word screwdriver into one corner and move around to break all the hot glue. You may need to use steel rulers to break the hot glue between the keys and the backplate.
    • After struggling for a while you should be able to take the backplate off.
  2. Lenovo W600 Keyboard Teardown, Removing the keys' backplate: 步骤 2 中的图像 1,2 Lenovo W600 Keyboard Teardown, Removing the keys' backplate: 步骤 2 中的图像 2,2
    • Unplug the FPC cable.
    • Use the same method as removing the backplate to break the hot glue between the keys and their backplate.
    • No more teardown process is possible without breaking the case of the keyboard.
_ Lithane
于08/18/17注册
101 声望
撰写一个指南
一条评论
i am experiencing a problem with my levovo w700 laptop keyboard. it is the problem as seen in this youtube vid - https://youtu.be/qmMcfFHCM60
any solutions.
i am using windows 7
Mr Keith S Boyd - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 805
