跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Lennox Y0349 Thermostat,请使用我们的维修手册
  1. Lennox Y0349 Thermostat Teardown, Thermostat: 步骤 1 中的图像 1,1
    • Here is the Lennox Y0349.
  2. Lennox Y0349 Thermostat Teardown, Remove the Thermostat from the Wall: 步骤 2 中的图像 1,1
    • Pushing in at the bottom of the thermostat, pull down and remove the thermostat from the wall. Note: the circuit breaker for the HVAC system MUST be off. Use caution when handling electrical wires.
  3. Lennox Y0349 Thermostat Teardown, Remove the Back Plate: 步骤 3 中的图像 1,2 Lennox Y0349 Thermostat Teardown, Remove the Back Plate: 步骤 3 中的图像 2,2
    • Locate the plastic tabs, and using a flat headed screwdriver, push them inward. This may take some force, but the plastic should give fairly easily.
  4. Lennox Y0349 Thermostat Teardown, Removing the Board and Display: 步骤 4 中的图像 1,3 Lennox Y0349 Thermostat Teardown, Removing the Board and Display: 步骤 4 中的图像 2,3 Lennox Y0349 Thermostat Teardown, Removing the Board and Display: 步骤 4 中的图像 3,3
    • The board is exposed! Now simply push back the plastic tabs connecting the board and disconnect the cables
  5. Lennox Y0349 Thermostat Teardown, Board and LCD - Closer Look: 步骤 5 中的图像 1,3 Lennox Y0349 Thermostat Teardown, Board and LCD - Closer Look: 步骤 5 中的图像 2,3 Lennox Y0349 Thermostat Teardown, Board and LCD - Closer Look: 步骤 5 中的图像 3,3
    • Now that the board is removed, we see 8 3 volt relays, the temperature and humidity sensor (on it's own board) a small battery, and the microprocessor.
    • The screen has 3 cables (the wide one is for the LCD, the skinny one if for the digitizer, and the simple, red and black one is for the backlighting.
  6. Lennox Y0349 Thermostat Teardown, Open the Display: 步骤 6 中的图像 1,1
    • The screen and be opened to expose the LCD and the backlighting
    • You've opened the Lennox Y049 Thermostat (or another similar model).
teardown-er
于02/20/21注册
537 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 45
总计 2,401
