简介
How to take apart the phone, and detach the logic board, screen, and microphones from the casing.
你所需要的
Press button labeled "Push". In the photo depicted the button is being depressed by the left finger.
Pull back panel toward bottom of phone.
Remove the five screws from the back panel, under the battery.
There is a hidden screw under the rubber pad next to the antenna. To remove this pad use a screwdriver to pry out rubber.
Starting at the top of the phone near the antenna, use a screwdriver or other small tool, maybe even fingernails, to pry the rear panel off.
By systematically prying up the edges of the back panel, moving about a quarter of an inch, and prying again, the panel will begin to lift off.
Don't be afraid to damage anything, the panel requires a bit of force to detach.
