跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的LG Tribute Royal,请使用我们的维修手册
  1. LG Tribute Royal Teardown, Remove back panel: 步骤 1 中的图像 1,3 LG Tribute Royal Teardown, Remove back panel: 步骤 1 中的图像 2,3 LG Tribute Royal Teardown, Remove back panel: 步骤 1 中的图像 3,3
    • Use a spudger to open the back panel and disconnect it from the phone.
  2. LG Tribute Royal Teardown, Unscrew all the screws: 步骤 2 中的图像 1,2 LG Tribute Royal Teardown, Unscrew all the screws: 步骤 2 中的图像 2,2
    • Unscrew all 16 screws holding the back panel cover on to the phone
  3. LG Tribute Royal Teardown, Remove back cover: 步骤 3 中的图像 1,2 LG Tribute Royal Teardown, Remove back cover: 步骤 3 中的图像 2,2
    • Apply adequate force to the back panel to remove it from the phone
  4. LG Tribute Royal Teardown, Remove battery: 步骤 4 中的图像 1,3 LG Tribute Royal Teardown, Remove battery: 步骤 4 中的图像 2,3 LG Tribute Royal Teardown, Remove battery: 步骤 4 中的图像 3,3
    • Disconnect the ribbon cable that connects the battery to the motherboard. I suggest you heat up the battery first because of the glue and not do what i did. Use spudger to pry up the battery from the device.
  5. LG Tribute Royal Teardown, Remove back camera: 步骤 5 中的图像 1,2 LG Tribute Royal Teardown, Remove back camera: 步骤 5 中的图像 2,2
    • Disconnect the back camera from the motherboard by disconnecting the connector from the motherboard
  6. LG Tribute Royal Teardown, Remove front camera: 步骤 6 中的图像 1,2 LG Tribute Royal Teardown, Remove front camera: 步骤 6 中的图像 2,2
    • Disconnect the front camera from the phone by disconnecting the ribbon cable from the front camera attached to the motherboard.
  7. LG Tribute Royal Teardown, Disconnect display: 步骤 7 中的图像 1,2 LG Tribute Royal Teardown, Disconnect display: 步骤 7 中的图像 2,2
    • Disconnect the display ribbon cable from the motherboard.
  8. LG Tribute Royal Teardown, Remove motherboard: 步骤 8 中的图像 1,2 LG Tribute Royal Teardown, Remove motherboard: 步骤 8 中的图像 2,2
    • To remove the motherboard apply adequate pressure because there will be some resistance. Try to avoid as much thermal paste as you can.
  9. LG Tribute Royal Teardown, Remove sim card and holder: 步骤 9 中的图像 1,2 LG Tribute Royal Teardown, Remove sim card and holder: 步骤 9 中的图像 2,2
    • To remove sim card just push it out the side. The sim card will be in the holder.
  10. LG Tribute Royal Teardown, Remove Vibrator Motor: 步骤 10 中的图像 1,2 LG Tribute Royal Teardown, Remove Vibrator Motor: 步骤 10 中的图像 2,2
    • Disconnect the ribbon cable holding down the vibrator motor then remove it.
  11. LG Tribute Royal Teardown, Remove Speaker: 步骤 11 中的图像 1,1
    • Remove the speaker at the top of the phone.
  12. LG Tribute Royal Teardown, Remove microphones: 步骤 12 中的图像 1,2 LG Tribute Royal Teardown, Remove microphones: 步骤 12 中的图像 2,2
    • Remove microphones
  13. LG Tribute Royal Teardown, Remove side buttons: 步骤 13 中的图像 1,2 LG Tribute Royal Teardown, Remove side buttons: 步骤 13 中的图像 2,2
    • Remove the side buttons by disconnecting the ribbon cables on each one.
  14. LG Tribute Royal Teardown, Reassemble the phone: 步骤 14 中的图像 1,1
    • Follow the steps backwards in order to reassemble the phone.
    • Be sure to clean the sim card with compressed air or else it wont work
Rose Schneider
于05/01/21注册
413 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 742
