拆解
Taking apart the phone
这个拆解是不是维修指南。 要维修你的的LG TP 1100,请使用我们的维修手册。
Unscrew and remove antenna from socket
Turn the phone over
Pull up on the tab at the top
Remove the Battery
Unscrew the four screws behind the battery
Pull off and remove the back cover
Do not separate the covers
Do not rip the tape connecting the two covers
Remove back cover
Pry the circuit board from front cover
Do not let number pad fall out
Now remove the number pad and navigation keys
Pry out microphone with opening tool
Slide opening tool into crevasse and pry open top cover
Do so on both sides
Do not completely remove cover
Pry out speaker with heavy-duty spudger
Caution: Do not disconnect the wires connecting the speaker, they are very fragile
与5其他贡献者
于04/10/10注册
1 声望
创作了3篇指南
徽章: 3
CPSU-AMIDO-S10S27G91
5 名成员
创作了11篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 5,073
