跳转到主内容
视频概述
这个拆解是不是维修指南。 要维修你的的LG KE970,请使用我们的维修手册
  1. LG KE970 Teardown, Remove the bottom plate: 步骤 1 中的图像 1,2 LG KE970 Teardown, Remove the bottom plate: 步骤 1 中的图像 2,2
    • Press this button to unlock and remove bottom plate
  2. LG KE970 Teardown, Disconnect Battery (Follow this guide until that step, if you need battery replacement): 步骤 2 中的图像 1,3 LG KE970 Teardown, Disconnect Battery (Follow this guide until that step, if you need battery replacement): 步骤 2 中的图像 2,3 LG KE970 Teardown, Disconnect Battery (Follow this guide until that step, if you need battery replacement): 步骤 2 中的图像 3,3
    • Insert your blackstick and remove the battery
  3. LG KE970 Teardown, Remove rubber screw covers: 步骤 3 中的图像 1,3 LG KE970 Teardown, Remove rubber screw covers: 步骤 3 中的图像 2,3 LG KE970 Teardown, Remove rubber screw covers: 步骤 3 中的图像 3,3
    • Find the hidden screws under the rubber covers.
  4. LG KE970 Teardown, Remove 6 screws from the back: 步骤 4 中的图像 1,2 LG KE970 Teardown, Remove 6 screws from the back: 步骤 4 中的图像 2,2
    • 6 same size screws should be removed.
  5. LG KE970 Teardown, Separate front and back part: 步骤 5 中的图像 1,3 LG KE970 Teardown, Separate front and back part: 步骤 5 中的图像 2,3 LG KE970 Teardown, Separate front and back part: 步骤 5 中的图像 3,3
    • Insert your blackstick and try to slide it from the one side to the other. At some point you can hear the "click" sound. It's really fragile so be careful. Don't put the blackstick too much inside because you might damage other parts. Try to be as gentle as you can. If you don't feel it, take your time. It's better if you do a break.
  6. LG KE970 Teardown, Disconnect the antenna: 步骤 6 中的图像 1,3 LG KE970 Teardown, Disconnect the antenna: 步骤 6 中的图像 2,3 LG KE970 Teardown, Disconnect the antenna: 步骤 6 中的图像 3,3
    • Once the two parts are separated we should disconnect the antenna to proceed further. Insert your blackstick under the antenna and push it up very gently.
  7. LG KE970 Teardown, Unscrew the front part: 步骤 7 中的图像 1,3 LG KE970 Teardown, Unscrew the front part: 步骤 7 中的图像 2,3 LG KE970 Teardown, Unscrew the front part: 步骤 7 中的图像 3,3
    • The display can be unscrewed. 6 silver screws are holding it on the main body. Although soldering required to replace this part, since the flex cable is attached on the Motherboard. So I leave it here.
  8. LG KE970 Teardown, Find the keyboard: 步骤 8 中的图像 1,3 LG KE970 Teardown, Find the keyboard: 步骤 8 中的图像 2,3 LG KE970 Teardown, Find the keyboard: 步骤 8 中的图像 3,3
    • Remove the last screw and you have access to the keyboard underneath.
Kosmar
于06/23/21注册
492 声望
创作了4篇指南
团队
ksmr.repair ksmr.repair 的会员
Business
1 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 531
