I have tried to include as much detail as possible in this teardown. I have even inspected the chips on the mainboard! Thanks for looking, and I hope you find this useful.
这个拆解是不是 维修指南。 要维修你的的LG GW300,请使用我们的维修手册 。
Get a thin opening tool and slide it around the bezel of the device.
Make sure you put it in the correct place, behind the silver bezel of the front of the phone!
The front and back of the device should separate.
Two buttons should come off after you have removed the back.
This is the rear speaker.
Both of these buttons need to be pried from the front casing to allow the mainboard to come away from the front housing.
These buttons are soldered to the mainboard so make sure you don't break them!
The front speaker also has to be pried from the front housing.
The LCD ribbon cable and connector are under a plastic sheet that has to be removed.
The ribbon cable can then be take out of the connector
The ribbon connector is very fragile, so be careful when lifting the lever.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
