跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的LG G Watch R,请使用我们的维修手册
  1. LG G Watch R Teardown, Front and Back: 步骤 1 中的图像 1,2 LG G Watch R Teardown, Front and Back: 步骤 1 中的图像 2,2
    • LG G Watch R assembly.
  2. LG G Watch R Teardown, Removing the back cover: 步骤 2 中的图像 1,2 LG G Watch R Teardown, Removing the back cover: 步骤 2 中的图像 2,2
    • First remove the watch band using a small flat screw driver to compress the spring loaded pin.
    • Remove the four T4 torx screws (Green).
    • Carefully pry the base off using a thin flat screw driver
  3. LG G Watch R Teardown, Removing the Board: 步骤 3 中的图像 1,2 LG G Watch R Teardown, Removing the Board: 步骤 3 中的图像 2,2
    • Disconnect the four electrical connectors from the board
    • Orange - Battery connector
    • Blue - button and charging connector
    • Green - Backlight
    • Purple - O-LED Controller + Mic
    • Remove the three phillips screws securing the board down. Then lift the board off the base
  4. LG G Watch R Teardown, The Battery: 步骤 4 中的图像 1,2 LG G Watch R Teardown, The Battery: 步骤 4 中的图像 2,2
    • The battery is below the board.
    • The battery can easily be pried out using a small flat head screwdriver.
  5. LG G Watch R Teardown, Battery housing: 步骤 5 中的图像 1,1
    • Using a small pliers and a small flat screwdriver the battery housing comes out easily.
  6. LG G Watch R Teardown, P-OLED Panel: 步骤 6 中的图像 1,3 LG G Watch R Teardown, P-OLED Panel: 步骤 6 中的图像 2,3 LG G Watch R Teardown, P-OLED Panel: 步骤 6 中的图像 3,3
    • Pictures of the front and back of the 1.3" P-OLED.
    • The screen is glued in.
8条评论
Is there a wifi antenna inside the LG G watch R?
Fernando Perez - 回复
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Mark Fortune -
Are there differences between the UK as US G Watch R?
James Kemble - 回复
Where could I find a battery for replacement?
Thanks in advance.
Fab - 回复
Any tips for what to check if the touchscreen turns on but is non-responsive ?
richard - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 20,258
