在此拆机指南中使用的工具
简介
I broke my LG 25UM58-P LCD panel. Since there weren't any teardowns or disassembly guides online, it was only fitting to do one before it went in the bin.
The base plate can be removed by undoing the screw as seen in the second image.
Captive D-Ring screw
The stand is secrured to the monitor frame with 2 Phillips screws.
The small cover needs to be pushed down to disengage the clip.
Slide up in order to reveal the screws.
2 x Phillips #1 screws
There are 2 Phillips #2 screws holding the lower trim, with the LG logo, onto the monitor.
The lower trim piece lifts off with some persuasion.
The screen is held on with an overengineered system of clip and tabs. The only method that personally worked, was to pry at the display and lever it out.
The guitar picks were used to hold the display panel up and prevent it from clipping back in.
Once you work your way around the edge of the display, and release all the clips, the panel will be free.
The rear cover separates from the LCD panel, revealing the surprisingly tiny control board
Some close-ups of the clips and mechanism used to secure the rear cover to the LCD panel
The panel model appears to be: LM250WW1
The LCD itself has the part number: BBSU1V 3467C2
The rear housing is stamped with the part number: MCK67880501
A closer look at the mounting method shows that there are a series of plastic "rods" that slide into slots on the LCD panel frame. The "rods" then attach to the clips on the rear housing as seen in Step 8.
Judging by the markings on the motherboard, it appears that the same PCB is used for the 34UM58.
The part number of the board appears to be: 692M000F-002 63624404
4 x #1 Phillips screws are used to secure the hinge plate to the back of the LCD panel.
2 x #2 Phillips screws are used to secure the hinge itself to the LCD panel.
Carefully route the cables away, from the hinge panel.
With the 6 screws removed from the previous step, the hinge assembly can be lifted away.
The LCD panel itself can be separated from the backlight.
Part number: BBSU1V 3467C2
A fairly tricky monitor to disassemble.
I'm 90% sure that removal of the LCD panel from the housing/frame will cause it to shatter (if it wasn't already damaged).
Replacement panels are about the same cost as replacing the entire monitor itself, making repairs unfeasible.
4条评论
Sorry to hear that happened. But it made for a really good teardown
I have 25UM57 internals are literally the same. same panel
Hi, quick question. Do you know if that long skinny board on the bottom has the T Con board integrated into it? Or is that located on the main board centered on the back? Any info would be helpful as I believe I have a T Con issue with mine. Thanks so much!
I quickly googled what the T-con is…
Do you know what specifically I should look for, maybe a chip? I’ll have a look through my unpublished pictures
