跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的LED Birne 230V,请使用我们的维修手册
  1. LED Light Bulb Teardown, Removing Diffuser: 步骤 1 中的图像 1,3 LED Light Bulb Teardown, Removing Diffuser: 步骤 1 中的图像 2,3 LED Light Bulb Teardown, Removing Diffuser: 步骤 1 中的图像 3,3
    • Carefully cut and pry with razor blades between the diffuser and body of light bulb.
    • Diffuser is sealed onto body of bulb.
  2. LED Light Bulb Teardown, Body without Diffuser: 步骤 2 中的图像 1,2 LED Light Bulb Teardown, Body without Diffuser: 步骤 2 中的图像 2,2
    • 15 LEDs spread in ring.
  3. LED Light Bulb Teardown, Cross section of body: 步骤 3 中的图像 1,3 LED Light Bulb Teardown, Cross section of body: 步骤 3 中的图像 2,3 LED Light Bulb Teardown, Cross section of body: 步骤 3 中的图像 3,3
    • Filing into the side of the bulb.
    • Top layer is circuit board.
    • V-shaped metal is casing about 1mm thick.
  4. LED Light Bulb Teardown, Removing Circuit Board: 步骤 4 中的图像 1,3 LED Light Bulb Teardown, Removing Circuit Board: 步骤 4 中的图像 2,3 LED Light Bulb Teardown, Removing Circuit Board: 步骤 4 中的图像 3,3
    • With open gap circuit board can be removed.
    • Attached with wire and resistor to base of bulb.
    • Release clips to release wires.
  5. LED Light Bulb Teardown, Remove Capacitor: 步骤 5 中的图像 1,3 LED Light Bulb Teardown, Remove Capacitor: 步骤 5 中的图像 2,3 LED Light Bulb Teardown, Remove Capacitor: 步骤 5 中的图像 3,3
    • Capacitor is removed as previous wires in Step 4 were removed.
    • Capacitor is 10 mircoFarads.
  6. LED Light Bulb Teardown, Remove Resistor: 步骤 6 中的图像 1,3 LED Light Bulb Teardown, Remove Resistor: 步骤 6 中的图像 2,3 LED Light Bulb Teardown, Remove Resistor: 步骤 6 中的图像 3,3
    • Resistor removed by popping of bottom cap.
    • Resistor is 4.7 ohms.
  7. LED Light Bulb Teardown, All Parts: 步骤 7 中的图像 1,3 LED Light Bulb Teardown, All Parts: 步骤 7 中的图像 2,3 LED Light Bulb Teardown, All Parts: 步骤 7 中的图像 3,3
    • Parts laid out and details.
Wieli
于01/08/23注册
1,707 声望
创作了12篇指南
3条评论
I'm curious, if anyone has taken apart enough failed LED light bulbs to discover if there is a trend in what part fails first. This would be interesting if it is a component that can potentially be replaced. A buck or less to get more life out of a $10 bulb seems like a good trade off!
jaeckerb - 回复
I've wondered the same thing myself. It seems likely that it would be a failing capacitor or possibly one of the LED's in a series circuit, where if one fails they all go off or flash as the failing LED works, heats up, fails, cools down, works again, and repeat) as often failed LED bulbs do.
Mike Klingler - 回复
Diode usually. you can take your meter and on both sides of each diode test each individually when it lights up u know that one is bad. pop bad led off with pick and take lead out of graphite pencil shaving on circuitry and/or. little drop of super glue to allow it to bond and test again light should be fixed.... easier done then explained lol.... god bless.
CryptoCros - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 90
过去 30 天: 449
总计 7,973
