跳转到主内容
简介
This will provide information on dissembling the phone to allow for repairs.
这个拆解是不是维修指南。 要维修你的的Kyocera Oystr,请使用我们的维修手册
  1. Make sure the phone is turned off before disassembly. Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing. Remove the battery from the casing. This is simply a precaution.
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over so that the front side is facing you. Flip open the device in preparation for the next step.
  2. Peel the Virgin Mobile sticker from the phone's screen, revealing two screws beneath it. Using the Tri-Wing Y0 screwdriver, remove the two screws from the screen. Using the Tri-Wing Y0 screwdriver, remove the two screws from the screen.
    • Peel the Virgin Mobile sticker from the phone's screen, revealing two screws beneath it.
    • Using the Tri-Wing Y0 screwdriver, remove the two screws from the screen.
  3. Lift the plastic cover of the phone screen upwards by prying around the perimeter of the screen with a plastic opening tool. After lifting the plastic cover from the screen, remove the two screws from the metal cover holding the screen in place. After lifting the plastic cover from the screen, remove the two screws from the metal cover holding the screen in place.
    • Lift the plastic cover of the phone screen upwards by prying around the perimeter of the screen with a plastic opening tool.
    • After lifting the plastic cover from the screen, remove the two screws from the metal cover holding the screen in place.
  4. Remove metal cover by lifting up and away from the device.
    • Remove metal cover by lifting up and away from the device.
  5. Remove the phone's speakers by using the plastic opening tool to pry up and away from the device. These speakers will dangle by the wires attached to the board. Use your fingernail to detach the ribbon connecting the board to the screen. Remove the damaged screen from the device.
    • Remove the phone's speakers by using the plastic opening tool to pry up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Follow steps in reverse order to replace Kyocera Oystr’s screen.
    • Follow steps in reverse order to replace Kyocera Oystr’s screen.
David
于2011年10月04日注册
24 信誉积分
创作了2篇指南
团队
UW Stout, Team 5-7, Zhou Fall 2011 UW Stout, Team 5-7, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S5G7
2 名成员
创作了4篇指南
where do I get a new screen?
LARS ANDERSEN - 回复
where do i get a new screen
thanks
LARS ANDERSEN - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 4,050
