跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Krups ESSENZA Nespresso XN 2140,请使用我们的维修手册
  1. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Preparations: 步骤 1 中的图像 1,2 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Preparations: 步骤 1 中的图像 2,2
    • Unplug the device from the mains. (Duh!),
    • Remove the water container and tray.
  2. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove 4 bottom screws: 步骤 2 中的图像 1,2 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove 4 bottom screws: 步骤 2 中的图像 2,2
    • Remove the 4 bottom screws that hold the side panels. You need the oval drive bit for this.
    • Leave the other 2 bottom screws in place, these hold the bottom plate in place.
    • When reassembling, take care not to over tighten these screws. When in doubt, take 1/4 turn back.
    • Improvement: As these oval head screws are (intended to be) a nuisance, you may want to replace them with similar screws with a more common head.
  3. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the side panels: 步骤 3 中的图像 1,3 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the side panels: 步骤 3 中的图像 2,3 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the side panels: 步骤 3 中的图像 3,3
    • Put the machine on one side, gently push the bottom edge of the side panel towards the top and lift it out.
    • Unhook the panel from the top.
    • Repeat with the other side panel.
    • The panels are identical, so there's no need to remember which was left or right.
    • When reassembling, make sure the bottom of the panel clicks fully closed before inserting the screws.
  4. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Take the lever off: 步骤 4 中的图像 1,3 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Take the lever off: 步骤 4 中的图像 2,3 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Take the lever off: 步骤 4 中的图像 3,3
    • Use a Torx T120 to remove the two black screws that hold the lever, one on each side.
    • Open the lever and slide it upwards from its axle.
    • When reassembling, the axle needs to be turned vertical before you can slide the lever back into place.
  5. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit cover: 步骤 5 中的图像 1,3 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit cover: 步骤 5 中的图像 2,3 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit cover: 步骤 5 中的图像 3,3
    • Use a Torx T10 to remove the 2 screws that hold the cover of the brew unit at the front
    • Remove the last screw (T10) of the cover, located at the back and underside.
  6. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the brew unit cover: 步骤 6 中的图像 1,2 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the brew unit cover: 步骤 6 中的图像 2,2
    • Slide the brew unit cover back so that it comes free.
    • No force needed, some manipulation will do the trick.
  7. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unlock the spout: 步骤 7 中的图像 1,3 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unlock the spout: 步骤 7 中的图像 2,3 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unlock the spout: 步骤 7 中的图像 3,3
    • Locate the clips that hold the brew unit, one on each side.
    • With your thumb(nail), push one sideways and and forward so that it frees the clip.
    • This takes a bit of force, but does not need to move the clip far.
    • Repeat on the other side.
  8. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Remove the spout: 步骤 8 中的图像 1,1
    • With both clips unlocked, remove the spout with a tilting downward motion.
    • When reassembling, you might want to temporarily loosen the front screws from the next step (9) to give the spout more room.
  9. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit: 步骤 9 中的图像 1,2 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Unscrew the brew unit: 步骤 9 中的图像 2,2
    • Use a Torx T10 ro remove the 4 screws that hold the the brew unit, 2 on each side.
  10. Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Lift the brew unit off: 步骤 10 中的图像 1,2 Krups ESSENZA Nespresso Teardown to Clean Blocked Output, Lift the brew unit off: 步骤 10 中的图像 2,2
    • Do NOT remove the hose
    • Lift the back of the brew unit.
    • Pull it backward until free.
    • Put it next to the machine, but do not put much strain on the hose.
    • Clean the spout, the front of the brew unit and anything that needs cleaning.
    • Once dry, it is ready to reassemble.
Altijd Ellende
于03/29/21注册
237 声望
撰写一个指南
团队
Repair Café De Pijp Repair Café De Pijp 的会员
Local Repair Groups
2 名成员
创作了1篇指南
2条评论
Thanks, @farmyardgaming for cleaning up my grammar!
Altijd Ellende - 回复
Anytime, I'm glad I could help!
FarmYard Gaming -
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 22
过去 30 天: 119
总计 5,998
