跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Kobo Forma,应参考我们的维修指南
  1. Kobo Forma Teardown, Remove Fingerplate: 步骤 1 中的图像 1,3 Kobo Forma Teardown, Remove Fingerplate: 步骤 1 中的图像 2,3 Kobo Forma Teardown, Remove Fingerplate: 步骤 1 中的图像 3,3
    • Careful: the fingerplate is glued down, and may not come off easily. Work slowly and use heat to soften the adhesive if needed, otherwise it can break off in pieces.
    • Remove the finger plate. Start in one corner and push in a spudger/flat blade and lever it up. It is glued all the way along and has clips at the bottom edge so you'll want to bend out the bottom edge to clear the clips.
  2. Kobo Forma Teardown, Remove the back cover: 步骤 2 中的图像 1,3 Kobo Forma Teardown, Remove the back cover: 步骤 2 中的图像 2,3 Kobo Forma Teardown, Remove the back cover: 步骤 2 中的图像 3,3
    • With the fingerplate removed, you can get a spugder in the bottom and lever off the backplate. Again it is stuck down with tape all the way round and has clips that break away easily. I don't suggest you do like I did and push a metal screwdriver all the way in, you could short out the battery. It is coated with some glue/lacquer, so maybe not!
  3. Kobo Forma Teardown, Remove battery & mainboard: 步骤 3 中的图像 1,3 Kobo Forma Teardown, Remove battery & mainboard: 步骤 3 中的图像 2,3 Kobo Forma Teardown, Remove battery & mainboard: 步骤 3 中的图像 3,3
    • The board is held down by some small (#0?) screws and the battery is stuck down with double sided tape. You will likely pierce the foil wrap when you try to remove it.
Max Allan
于06/10/23注册
97 声望
撰写一个指南
3条评论
I think my battery needs replacing. It won't hold a charge for long. Did you get your ereader to work again?
H. Koops - 回复
I think it should be noted that it is not necessary to remove the fingerplate to access the battery. It is possible to replace it by just removing the back cover.
Hermosilla - 回复
Hi @antonioher64178 - are you saying it is possible to remove the back cover without removing the fingerplate, and not cause any damage?
TIRTHA SARKAR -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 115
总计 2,192
