简介
Look and be amazed! Amazon has added a new tablet to its e-reader lineup, and this one aims to perfect the reading experience. But can it beat Amazon's rocky repairability record? Join us on an incredible journey to the center of the Voyage, and find out just what's inside.
Read all about it! Tech and teardown talk can be found on Facebook, Instagram, and Twitter!
你所需要的
If you're looking for specs to blow your tablet-addled mind, look elsewhere. What we have here is an e-reader, and it does things its own way:
6" display with Carta e-paper technology at a resolution of 300 ppi
4 GB storage capacity
802.11b/g/n Wi-Fi
Built-in light + adaptive light sensor
PagePress sensors with haptics
Kindle Voyage with Apatosaurus (aka Brontosaurus) for scale.
This one's only a model.
The
2001 SpaceVoyage is branded with the model number NM460GZ.
The Kindle Voyage proves to be a hybrid of Paperwhite and Fire parentage with its rear bezel access panel, revealing...
...some screws and some antenna components. Now to get the rest of the cover off.
It's a sliiiiide! A slide-off cover, that is—there's not a lick of adhesive in sight after removing the top portion. Neat!
It didn't take long to get to the heart of the Voyage. This reader is powered by a 3.8 V
mixed metaphorbattery rated at 1320 mAh. -
We apply some oomph in the form of a Plastic Card to free the battery from its sticky patch.
The Kindle (7th Gen) claimed a useful life of up to four weeks from its 890 mAh unit.
The more versatile Kindle HD 6's onboard reactor weighs in at a whopping 3400 mAh, but it's rated for just 8 hours of normal use.
Having Jimmy'd our way this far, we take a stab at removing the vibrator.
Since the triggers themselves have no moving parts, the vibrator gives
taptichaptic confirmation of all your page-turning commands. -
After doing our IC identification homework, we can report that this is no ordinary oscillator or motor, but rather a piezo haptic vibrator, perhaps manufactured by AAC Technologies?
What makes a Kindle Voyage a real trip and not just a paperweight?
An ambient light sensor, for automatically adjusting the display brightness is a must.
We found this sensor nestled within a socket on the display assembly, near the end of a long cable that connects to the backside of the motherboard.
Let's take a look at the ICs that drive the Kindle Voyage:
Toshiba THGBM5G5A1JBAIR 32 Gb (4 GB) eMMC NAND Flash
Freescale Semiconductor MCIMX6L8DVN10AB Applications Processor
Samsung K4P4G324EQ-RGC2 4 Gb (512 MB) LPDDR2 SDRAM
Maxim Integrated MAX77696A Power Management Integrated Circuit (PMIC)
Atheros AR6803G-BL3B WLAN Controller
Freescale Semiconductor M05R5V 1N96F ACBIT
Texas Instruments DRV2667 Piezo Haptic Driver
The last of the Voyage's bonus features live under the display glass. After an off-screen iOpener application, we're ready to pry through some glue.
Thankfully, it's not the terrible tar we sometimes encounter. Combine this mild-mannered adhesive with thick, tough display glass and a rubbery bezel, and it's a pretty easy pry job.
Look at that e-ink screen! Still displaying text like a chicken with its head cut off (and battery removed...)
As we continue to explore the Voyage, we come across the PagePress sensors. The sensors are held to the display assembly with some mild adhesive for good contact.
"PagePress is a custom-designed force sensor made of carbon and silver, which reacts to a subtle increase of pressure, triggers a page-turn, and provides a haptic response only your thumb can perceive."
Sounds like some kind of strain gauge implementation to us. A strain gauge is a component that changes resistivity when deformed, making for an excellent buttonless button.
Kindle Voyage Repairability Score: 7 out of 10 (10 is easiest to repair).
Several modular components can be replaced individually.
Screws secure a slide-off rear case, simplifying opening procedure compared to other Kindles.
Thanks to mild front panel adhesive, thick display glass, and a soft bezel, prying up the glass is fairly easy with the right tools.
Glass strengthens the Kindle and protects the display, but is susceptible to cracking.
Battery is easy to get to, but has stronger adhesive than is necessary.
The front glass and e-ink display are fused together, increasing the cost of repairs.
21条评论
Very interesting teardown!
I am interested in permanently disabling the screen light on a Kindle Voyage. (You can adjust the brightness but not all the way off. I don't want any light.) Based on your tear down experience how hard would it be to disable the lights and reassemble a working Kindle? Thanks.
Then why spend money on this most expensive kindle? Just return this and get the cheapest model and you don't have back light anymore.
How to you "unfuse" the screen and e-ink? My voyage has a hairline Crack down the middle and I bought a new voyage screen but I don't know of how to switch them?
