跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Kindle Fire HD 2013,请使用我们的维修手册
  1. Kindle Fire HD 2013 Teardown, Kindle Fire HD 2013 Teardown: 步骤 1 中的图像 1,2 Kindle Fire HD 2013 Teardown, Kindle Fire HD 2013 Teardown: 步骤 1 中的图像 2,2
    • Here it is, the Kindle Fire HD 2013—and it's bringin' the heat:
    • 7" HD display; 1280 x 800 at 216 ppi with IPS technology, polarizing filter, and anti-glare finish
    • 1.5 GHz dual-core processor with Imagination PowerVR 3D graphics core
    • Dual-band Wi-Fi antenna
    • Dolby Audio with dual stereo speakers
    • 8 or 16 GB internal storage
  2. Kindle Fire HD 2013 Teardown: 步骤 2 中的图像 1,2 Kindle Fire HD 2013 Teardown: 步骤 2 中的图像 2,2
    • What is this? A certified frustration-free opening procedure? Nice.
    • Hopefully that applies to the device along with the packaging…
    • And we're in…the box. Here's the first glamour shot of our new prize.
    • This would be considered the "before" shot; we like to show off the total transformation our gadget surgery provides.
  3. Kindle Fire HD 2013 Teardown: 步骤 3 中的图像 1,2 Kindle Fire HD 2013 Teardown: 步骤 3 中的图像 2,2
    • A quick glance at the rear case reveals Amazon's smiling facelogo and newly prominent power and volume buttons.
    • A quick close-up reveals the model number: P48WVB4.
    • Other findings include speaker grilles, power requirements, FCC info, and the standard "Made in China".
    • At a guess, the hand-level speaker slats will turn your cupped palms into parabolic amplifiers. That is, as long as you don't put your fingers directly on top of them…
  4. Kindle Fire HD 2013 Teardown: 步骤 4 中的图像 1,2 Kindle Fire HD 2013 Teardown: 步骤 4 中的图像 2,2
    • Ports! We've got ports! Get 'em while they're hot.
    • Headphone jack up top, Micro-USB on the bottom. Like the flounder, Amazon seems to be shifting its vitals around.
    • Contrasting last year's Fire HD, which had ports on the side and bottom, this year's port layout was assuredly driven by some internal component shifts. We look forward to finding out what they are!
  5. Kindle Fire HD 2013 Teardown: 步骤 5 中的图像 1,3 Kindle Fire HD 2013 Teardown: 步骤 5 中的图像 2,3 Kindle Fire HD 2013 Teardown: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    购买
    • Despite the fiery name, we're happy to find we don't need heat to open this Kindle. So far, a plastic opening tool and an opening pick are all we need.
    • Heatless opening procedures make us all warm and fuzzy inside—it means that when your device loses its spark, you can keep your cool with easy repairs.
    • We made it! What do we have here?
    • Big battery: check.
    • Motherboard: check.
    • It looks like every tablet we've opened; let's see if we can find something a bit more interesting…
  6. Kindle Fire HD 2013 Teardown: 步骤 6 中的图像 1,3 Kindle Fire HD 2013 Teardown: 步骤 6 中的图像 2,3 Kindle Fire HD 2013 Teardown: 步骤 6 中的图像 3,3
    • The volume buttons come out easily enough, once we liberate the volume bracket from the rear case.
    • The button assembly is hefty, which means we won't lose it and can replace it, even with our big meaty claws.
  7. Kindle Fire HD 2013 Teardown: 步骤 7 中的图像 1,3 Kindle Fire HD 2013 Teardown: 步骤 7 中的图像 2,3 Kindle Fire HD 2013 Teardown: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Spudger
    $3.99
    购买
    • A reasonable amount of adhesive holds the battery in place; we make short work of it with some fancy spudgering.
    • Verdict: The battery is more replaceable than some of the tablets we encounter, but slim design still rules.
    • The 3.7 V, 4440 mAh battery boasts 10 hours of power during mixed usage—a decrease from the 2012 HD edition. Amazon calls it an increase in battery life compared to the "previous generation Kindle Fire."
    • Let us break it down for you: This HD is really the new Kindle Fire and the Kindle Fire HDX will be the new Kindle Fire HD. Confused yet?
    No need to remove the battery to replace the screen, if that's why you are on this excellent site!
    staciejohnson91 - 回复
  8. Kindle Fire HD 2013 Teardown: 步骤 8 中的图像 1,3 Kindle Fire HD 2013 Teardown: 步骤 8 中的图像 2,3 Kindle Fire HD 2013 Teardown: 步骤 8 中的图像 3,3
    • We pop out the dual speakers to see just what this Dolby Digital Plus speaker system is all about.
    • Not only does your tablet have virtual surround sound, but it has clarity-optimized sound, with or without headphones. So you can be creeped out by this barber shop experience even without your beets by Dr. Dre.
  9. Kindle Fire HD 2013 Teardown: 步骤 9 中的图像 1,2 Kindle Fire HD 2013 Teardown: 步骤 9 中的图像 2,2
    • Some dainty spudgering and a few twists of our screwdriver, and the motherboard is free as the wind
    • …but not free enough. We still need to get under those pesky EMI shields and reveal the secrets nestled in this Kindle's brain.
  10. Kindle Fire HD 2013 Teardown: 步骤 10 中的图像 1,1
    • The front side of the Kindle Fire HD's motherboard is occupied by the following ICs:
    • Toshiba THGBMAG6A2JBAIR 64 Gb (8 GB) e-MMC NAND Flash
    • Micron 3HAI8 D9QQD 8 Gb (1 GB) Mobile LPDDR2 SDRAM
    • We believe that the 1.5 Ghz Dual Core TI OMAP4 (4470) HS processor is nested underneath the Micron SDRAM IC.
    • Synaptics S7301B Touchscreen Controller
    • Texas Instruments TWL6032 Fully Integrated Power Management with Power Path and Battery Charger
    • InvenSense MPU-6500 6-axis gyroscope
    • 347 CB307
    Seems like this may be hackable using the Reset, USB boot, and power buttons directly on the board. Also looks like there is a JTAG port using TP1500-TP1506.
    And where is the image for the back of the PCB
    Alex - 回复
    So where can I get new glass? I fear that this model is too new, because I can't find a replacement ANYWHERE!!
    trappleye - 回复
    I'm looking for glass digitizer also.... Any clues?
    Chris Halliwell - 回复
    I am looking for this digitizer also. it is nowhere to be found
    Jeremy Goldy - 回复
    Anybody found the digitizer yet? Spent hours searching with no success
    Martyn Biddle - 回复
    need digitizer also, found several for different models but not for this one......HELP
    Thomas Spurling - 回复
    Also need front glass. Found for other models but not the P48WVB4. Help!!!
    aelpn - 回复
    Where is reset button?
    Vieux Gadiga -
    I realize this is old but I'm wondering how to access the reset port on the motherboard. Or if not the port then is there something on the motherboard that will allow me to reset once its disconnected?
    Brittany Melby - 回复
    i'm trying to find the back-light inverter/controller as my back-light has lost power
    RoWaN MiFTY - 回复
  11. Kindle Fire HD 2013 Teardown: 步骤 11 中的图像 1,2 Kindle Fire HD 2013 Teardown: 步骤 11 中的图像 2,2
    • A couple of close-ups for the tiny guys:
    • Broadcom BCM4330 802.11a/b/g/n MAC/Baseband/Radio with Integrated Bluetooth 4.0+HS & FM Transceiver
    • Maxim Integrated MAX98090 Ultra-low Power Stereo Audio Codec
    • Maxim Integrated MAX97236 Audio Amplifier
  12. Kindle Fire HD 2013 Teardown: 步骤 12 中的图像 1,3 Kindle Fire HD 2013 Teardown: 步骤 12 中的图像 2,3 Kindle Fire HD 2013 Teardown: 步骤 12 中的图像 3,3
    • We love modularity. The separate and easily-removable headphone jack and Micro-USB connectors are exciting to find, especially compared to long strings of components that make repair pricier and more difficult.
    • Out comes the midframe. While the material is unconfirmed, the possibility of magnesium kindles the firebug in us.
  13. Kindle Fire HD 2013 Teardown: 步骤 13 中的图像 1,3 Kindle Fire HD 2013 Teardown: 步骤 13 中的图像 2,3 Kindle Fire HD 2013 Teardown: 步骤 13 中的图像 3,3
    • The display once again comes courtesy of LG. And just like last time, it's a mouthful: the LD070WX6-SM01. Gesundheit!
    • The front glass panel separates easily from the display, a return to the Kindle Fire construction.
    • Yet more evidence that, while the Kindle Fire HDs share the same name, the 2013 model descends from the Kindle Fire lineage. Search your feelings, you know it to be true.
    • The LCD is piloted by a Novatek NT50169D LCD display driver.
    • Novatek Microelectronics Corp. is a chip design company that makes display driver ICs.
    • It should not be confused with Novatek, Russia's largest independent natural gas producer.
  14. Kindle Fire HD 2013 Teardown: 步骤 14 中的图像 1,2 Kindle Fire HD 2013 Teardown: 步骤 14 中的图像 2,2
    • Kindle Fire HD 2013 Repairability Score: 8 out of 10 (10 is easiest to repair).
    • Simple, modular design means the few components that might fail can be easily, inexpensively replaced.
    • All the fasteners found inside are Torx T5 screws—one non-proprietary screwdriver is all you need.
    • The LCD is not fused to the display and can be easily removed.
    • The rear case is a little difficult to open, but it should be easy with directions.
    • A decent amount of adhesive is used on the battery, meaning some prying and gentle working is required for disassembly.
    • The glass panel is glued to the front plastic frame, so a heat gun will be required for replacing cracked glass (or you have to replace both components together).
4条评论
Where is the wifi atenna located?
Andres Bel - 回复
seem to be missing buttons to switch it on and volume
Margaret Power - 回复
after replacing battery missing piece to switch power on or off and volume
Margaret Power - 回复
yes here is the antenna, and if mine isn’t connecting to wifi does it mean its likely broken.?
sean dodwell - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 32
总计 64,868
