跳转到主内容
修复你的物品
维修的权力
配件 & 工具
本拆机指南正在进行中 – 定期刷新以看到更新!
在此拆机指南中使用的工具
简介
I want to show how to open up the headphones. Many headphones have just a broken cable but without knowing how to get in you having a hard time.
  1. first remove the ear cups. They are quite tight so removing feels a bit rough.
    • first remove the ear cups. They are quite tight so removing feels a bit rough.
    • Pull the cups with two fingers to the side off the speakers.
    • start with one spot and work your way around from there.
    • If they don't come off, try another spot and try again. Then you can see where the screw are and loosen them.
    • repeat for both sides
  2. Now you see three screws on each speaker. Grab your PH1 srew driver and remove them.
    • Now you see three screws on each speaker.
    • Grab your PH1 srew driver and remove them.
    • Carefully pull the speakers out. Check if there are cable hanging. If so grab the plastic bit and pull it out too.
    • They may come out as one speaker module. You see on one side is a venting hole to compensate the pressure during bass heavy music.
  3. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  4. Now in the speaker cases in the left side is the lipo battery with a protection circuit under the green tape
    • Now in the speaker cases
    • in the left side is the lipo battery with a protection circuit under the green tape
    • this protection circuit cuts the power if there is a shorted cable(overcurrent)
    • The PCB next to the battery is just to connect the wires from the other side(power and speaker)
    • Please note this is already in modified state. I changed the wires because the cable was broken in the headphones.
  5. PCB with charging circuit and Bluetooth module the twisted black and red wire is the microphone
    • PCB with charging circuit and Bluetooth module
    • the twisted black and red wire is the microphone
pa sch
于2017年07月01日注册
13 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 59
