简介
We will not be tearing the whole thing apart; just the big pieces
This loudspeaker was tinkered at the charge port (installation of a new one).
你所需要的
视频概述
Use a plastic spatula or credit card to open the grids
You should not have to exert too much force on the grids. There is a little bit of glue on it.
Remove the first 4 screws
Blow up the round of plastic then take care of the remaining 4 screws.
Now you can access the motherboard.
To disconnect the battery: disconnect the microphone first, it will make things easier.
Unscrew the two screws of the white cover
Get out of his notch, and here's the battery!
Nice tutorial on how to dismantle the device, but what if I want to separate out the power bank part of this device and dump the rest due to worn out speakers. Is it possible to do that? If not, will it still work as a power bank if I simply the wires to the speakers and remove them. I’d rather remove the amplifier as well so that unnecessary power consumption is reduced.
10等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
13条评论
About to try this, will give feedback
This is the charge2 + not the charge2
The Daniel - 回复
there aren,t any screws in the cap
I have the same problem. I think this is a TL model, but I have not been able to find any information on how to correctly remove the end caps. I don’t want to scratch or break anything trying to pop the end caps off.
Bobcov -
Thanks so much! I had a broken bit of plastic inside the tube after I left my speaker in my checked luggage and it got smashed around. I followed the instructions and managed to get it out, the speaker is purring again without the annoying ass rattle!! You're a legend my friend. TY
itgotfixed - 回复
You are welcome !
Hello, I have a problem
I lost the speaker screws
can you tell me what type of screws I have to buy?
thank you in advance
Bobo amputaa
Ce tuto ne concerne PAS le charge 2, mais bien le charge 2+
Le principe d’ouverture est bien différent !
So easy steps to follow. Thank you so much. The guide is really helpful.
It came handy when my boss complained about a fault, so I tried figuring it out, then I googled steps to dismantle, and pop! The video showed up. Really helpful. Thanks
omo4rmzion - 回复
This tutorial really helped :)
JITHIN ROY - 回复
Bonjour à tous, je constate que sur ce tuto on a des personnes qui gèrent donc bcp d'amitié
et de remerciement à tous vous êtes tjrs en mode cool et ça fait vraiment merci et n'hésitez pas à me demander un service
je serai fier de vous rendre service et encore merci Thameur
comme vous l'avez sans doute compris "bcp plaisir"
