跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Innovative Technology iPod Docking Station IT-5022WHT,请使用我们的维修手册
  1. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Overview: 步骤 1 中的图像 1,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Overview: 步骤 1 中的图像 2,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Overview: 步骤 1 中的图像 3,3
    • Before Teardown
    • Condition: Well used
    • Noted issue: static sound when adjusting volume.
  2. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Opening the Back Panel: 步骤 2 中的图像 1,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Opening the Back Panel: 步骤 2 中的图像 2,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Opening the Back Panel: 步骤 2 中的图像 3,3
    • Remove back battery panels. There are two: the main panel, and the smaller back up panel behind the main.
    • Remove the 9 phillips screws.
  3. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Look at the Guts: 步骤 3 中的图像 1,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Look at the Guts: 步骤 3 中的图像 2,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Look at the Guts: 步骤 3 中的图像 3,3
    • Speakers
    • Display & Logic Board
    • Top panel buttons board
    • Audio Jacks
    • DC Power Connector
    • Antenna
  4. Innovative Technology iPod Docking Station IT-5022WHT Teardown, DC Power Board and Audio Jacks: 步骤 4 中的图像 1,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, DC Power Board and Audio Jacks: 步骤 4 中的图像 2,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, DC Power Board and Audio Jacks: 步骤 4 中的图像 3,3
    • DC Power Board
    • Audio Jacks board
    • Remove the two screws
    • The boards are glued in, so carefully pry them out of the casing.
  5. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Antenna Removal: 步骤 5 中的图像 1,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Antenna Removal: 步骤 5 中的图像 2,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Antenna Removal: 步骤 5 中的图像 3,3
    • You can pull the antenna apart without opening the entire case. This is helpful if just part of the antenna is bent.
    • For full removal, remove the screw on the bottom of the box labeled "antenna", and slide the antenna out the top.
    • Coax cable connects the antenna to the tuning circuit on the upper PCB.
  6. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Speakers: 步骤 6 中的图像 1,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Speakers: 步骤 6 中的图像 2,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Speakers: 步骤 6 中的图像 3,3
    • Remove three screws holding the three mounting brackets for each speaker.
    • Use a blade to remove the glue holding the speaker wires in.
    • Carefully pry the speakers off their mounting points because they are glued in.
  7. Innovative Technology iPod Docking Station IT-5022WHT Teardown, LCD Panel and Logic Board: 步骤 7 中的图像 1,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, LCD Panel and Logic Board: 步骤 7 中的图像 2,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, LCD Panel and Logic Board: 步骤 7 中的图像 3,3
    • Removing the LCD Panel and motherboard.
  8. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Top Panel Buttons Board: 步骤 8 中的图像 1,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Top Panel Buttons Board: 步骤 8 中的图像 2,3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Top Panel Buttons Board: 步骤 8 中的图像 3,3
    • Remove 6 screws
    • Pry out the panel by hand
    • Careful of the volume and tuning nobs when pulling the board down
    • Check out that coil
  9. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Exploded View: 步骤 9 中的图像 1,1
    • Overall this product was pretty easy to take apart.
    • The internals were pretty easy to identify based on their location and appearance.
    • One drawback was that the speakers were glued in. The glue prevents rattling, but makes the speakers harder to get to. Some glue should be used when replacing the speakers.
    • 8/10 repairability
Dylan
于11/24/14注册
66 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 938
