简介
This is a guide to take apart the Honeywell HF-910 Fan. This guide will allow you to clean the fan or replace broken parts.
你所需要的
First, locate 6 screws along the cage of the fan
Remove these 6 screws with phillips head screwdriver
Remove cage of fan
The fan should now look like the first picture
Locate the two phillips head screws behind the blades
Remove these screws
Remove the two screws that are circled in the photo
The motor becomes loose with only the wires holding it in place
Remove the screw that is circled in the first picture to access the speed control wires
The wires connecting to the speed controller are shown in picture #2
