简介
Product Number 1504300014V0
Remove rubber covers first. Attached with some weak glue, they are relatively easy to pry away. Only the 2 at the back of the device have screws underneath.
Use a screwdriver to remove the screws.
Plastic tabs line the case where the upper and lower halves meet.
I found it easiest to start prying from the sides of the back.
Keep prying until the case is fully separated and the top half lifts up/forwards.
Ethernet switch: Realtek RTL8363SC sibling datasheet 1, sibling datasheet 2, programming guide
Ethernet magnetics: Bothhand/Pulse Electronics LG2P109RN datasheet
Step-down converters (2x): Fitipower FR9854 datasheet
Serial NOR SPI flash (16Mb): Macronix MX25U1633F2I datasheet
LED driver: Rohm BD2651MWV sibling datasheet 1
DRAM (2x 2Gb): Samsung K4B2G1646F-BYMA datasheet, product page
Squeeze the tip of the heatsink legs (e.g. with pliers) so you can pull them back through the PCB holes.
SoC: Intel FHCE2703 SR3SA (Puma 7) related products
DOCSIS cable tuner: MaxLinear MxL277 product page
DOCSIS upstream amplifier: MaxLinear MxL 236 product page
Lift the PCB away from the case.
Serial NAND EEPROM (1Gb): Kioxia TC58NVG0S3HTA00 datasheet
Debug headers factory firmware bootlog
Product number 383300420402-11
Unpopulated connector H084E0581B
Various test points (labeled "TPXXX")
602 910
V39 3601 2049
U710
