跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的HTC Evo 3D,请使用我们的维修手册
  1. HTC Evo 3D Teardown, HTC Evo 3D Teardown: 步骤 1 中的图像 1,1
    • First things first, Remove the back cover, battery and SD card.
  2. HTC Evo 3D Teardown: 步骤 2 中的图像 1,1
    • Remove the four T5 Torx screws.
    • Then remove the two Phillips screws.
    • *Very sorry for dark image*
  3. HTC Evo 3D Teardown: 步骤 3 中的图像 1,1
    • Once the screws are all out from the exterior back case, Begin separating the front housing from the back by using a spudger or any similar tool.
    • Begin from the bottom were the battery bay is, It is the easiest way.
    • Be careful of ribbons behind the plastic
  4. HTC Evo 3D Teardown: 步骤 4 中的图像 1,3 HTC Evo 3D Teardown: 步骤 4 中的图像 2,3 HTC Evo 3D Teardown: 步骤 4 中的图像 3,3
    • Once separated begin to remove the LED board. Apply only light upward force and it will detach itself.
  5. HTC Evo 3D Teardown: 步骤 5 中的图像 1,2 HTC Evo 3D Teardown: 步骤 5 中的图像 2,2
    • Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
    • Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
    • Example: bottom left is unlocked, bottom right is locked. upper left has bin finished and removed.
    • Tuck the ribbons in without bending or making tears in them.
  6. HTC Evo 3D Teardown: 步骤 6 中的图像 1,1
    • Behind the main board is two more ribbon's.
    • Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
    • Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
    • As a side note, the grey tape on the back side of the board was covering the clips so i cut a small section for this guide.
  7. HTC Evo 3D Teardown: 步骤 7 中的图像 1,1
    • This concludes the (simple) teardown of the Evo 3D.
_Z_
于03/18/12注册
9,668 声望
创作了2篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,521篇指南
一条评论
Thanks. This was very helpful.
dano706 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 19,431
