跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的HP Compaq 8200 Elite,应参考我们的维修指南
  1. HP Compaq 8200 Elite Teardown, Remove the cover: 步骤 1 中的图像 1,3 HP Compaq 8200 Elite Teardown, Remove the cover: 步骤 1 中的图像 2,3 HP Compaq 8200 Elite Teardown, Remove the cover: 步骤 1 中的图像 3,3
    • There are no screws to remove, simply pull the handle on the cover towards you
    • It is recommended that you do this with the PC flat on the floor
  2. HP Compaq 8200 Elite Teardown, Remove the front cover: 步骤 2 中的图像 1,3 HP Compaq 8200 Elite Teardown, Remove the front cover: 步骤 2 中的图像 2,3 HP Compaq 8200 Elite Teardown, Remove the front cover: 步骤 2 中的图像 3,3
    • There are 3 labelled tabs
    • Pull gently upward to release them
  3. HP Compaq 8200 Elite Teardown, Remove the CD-ROM: 步骤 3 中的图像 1,3 HP Compaq 8200 Elite Teardown, Remove the CD-ROM: 步骤 3 中的图像 2,3 HP Compaq 8200 Elite Teardown, Remove the CD-ROM: 步骤 3 中的图像 3,3
    • Press down on the green button
    • Pull the drive backwards until you hear a small click, then raise it out of the caddy.
  4. HP Compaq 8200 Elite Teardown, Raise the drive caddy: 步骤 4 中的图像 1,2 HP Compaq 8200 Elite Teardown, Raise the drive caddy: 步骤 4 中的图像 2,2
    • The drive caddy can be raised to allow access to the 3.5" drive bay below the CD-ROM
    • You don't have to remove the CD-ROM to do this.
    • This makes it easier to access the next 3.5" bay, too.
  5. HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: 步骤 5 中的图像 1,3 HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: 步骤 5 中的图像 2,3 HP Compaq 8200 Elite Teardown, Remove the 3.5" Drive: 步骤 5 中的图像 3,3
    • The power supply is hinged, and swings away to reveal a 3.5" bay below.
    • As with the CD-ROM, press the green button to release the drive.
    • Pull back then up to remove.
    • Depending on your configuration, there may not be a drive in this bay.
  6. HP Compaq 8200 Elite Teardown, Access the PCI-E slots: 步骤 6 中的图像 1,3 HP Compaq 8200 Elite Teardown, Access the PCI-E slots: 步骤 6 中的图像 2,3 HP Compaq 8200 Elite Teardown, Access the PCI-E slots: 步骤 6 中的图像 3,3
    • In the bottom-right corner, there is a tab
    • Lifting this up allows screw-free installation of PCI-E cards.
  7. HP Compaq 8200 Elite Teardown, Remove the fan shroud: 步骤 7 中的图像 1,3 HP Compaq 8200 Elite Teardown, Remove the fan shroud: 步骤 7 中的图像 2,3 HP Compaq 8200 Elite Teardown, Remove the fan shroud: 步骤 7 中的图像 3,3
    • Make sure to unclip the cables routed through the shroud before removing it.
    • Only a very minor amount of force is required to remove the shroud.
    • This will allow you to replace the CPU heatsink or fan.
  8. HP Compaq 8200 Elite Teardown, Points of interest: 步骤 8 中的图像 1,3 HP Compaq 8200 Elite Teardown, Points of interest: 步骤 8 中的图像 2,3 HP Compaq 8200 Elite Teardown, Points of interest: 步骤 8 中的图像 3,3
    • This workstation comes with spare Torx screws.
    • 5 Silver, 5 Black
    • Mine is missing one
    • These are also bitted for a flathead, but I had no luck actually unscrewing with one, so it's not recommended.
    • They are screwed into the chassis under the front cover
    • All screws in this device are Torx TR20. Ensure you have the correct bits before attempting board replacements
Darohan
于05/07/23注册
283 声望
撰写一个指南
5条评论
I want this (pcb)motherboard please show amount
Manoj subhash narwade - 回复
i accadentally blew it up
Cosmo - 回复
thanks i needed this<3
Vega Star - 回复
I powered off correctly but next day computer failed to power on I tried to change power cable it didn't work no even the sign of light in motherboard. What will be the problem?
JAMES MWALUKO - 回复
I want to install new PSU, but the weird 4 pin connector doesn't look like anything on my thermaltake700 w (overkill, but just in its box here) can anyone help?
David Gagné - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 60
过去 30 天: 175
总计 4,163
