跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Graphics Tablet,请使用我们的维修手册
  1. Graphics Tablet Stylus Teardown, Pen: 步骤 1 中的图像 1,1
    • First, carefully pull off the little plastic piece number 1. You must use a knife or something with sharp edge to wedge.
    • After this, you are ready to disassemble pen's exterior case, pulling strongly between parts 3 and 4. If it's hard, you can turn pieces 3 and 4 between them, but only a bit because electronics inside has a guide that lock it into the case.
  2. Graphics Tablet Stylus Teardown: 步骤 2 中的图像 1,1
    • This is what you are going to find inside. Next step is release primary and secondary buttons (piece nº 2) pulling up straightly and softly, being carefull do not break a and b parts that hold the button.
    • Other piece we must take care is piece number 5, which is quite fragile because is glued to the board through 2 thin wires that could brake. This part keeps wet around the wire and we must dry it perfectly keeping it warm.
    • Point number 6 shows how board engages the pen case. This is why we might no turn too much pieces 3 and 4 between them in step 1 to keep us avoid to break the circuit board.
  3. Graphics Tablet Stylus Teardown: 步骤 3 中的图像 1,1
    • And here is what's inside a graphic tablet ballpen and what i've broke disassembling.
    • I hope this tutorial helps you, now that you know what's inside a graphic tablet pencil, you'll gess which is your trouble.
pelos
于06/13/10注册
136 声望
撰写一个指南
3条评论
Awesome, just what I needed! It was driving me nuts trying to get this thing apart. I kind of deduced it needed pulling apart, but didn't quite realize I needed to take that one tab thing off there first. Thanks for the information!
MrsDubin - 回复
Thanks a lot, worked like a charm. To go further about fixing the iron core, see this blog :http://abiyasa.com/blog/2008/04/06/fixin...
Leo Grasset - 回复
i'm glad to be helpfull. :)
pelos - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 40
总计 28,218
