跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Google Home Mini,请使用我们的维修手册
  1. Google Home Mini 拆解, Google Home Mini 拆解: 步骤 1 中的图像 1,1
    • Google Home Mini是从底部打开的。在底部有一个橙色的橡塑圆盘粘在设备上。
  2. Google Home Mini 拆解: 步骤 2 中的图像 1,3 Google Home Mini 拆解: 步骤 2 中的图像 2,3 Google Home Mini 拆解: 步骤 2 中的图像 3,3
    • 利用金属撬棒拆解,将其置于外壳和橡胶塑料圆盘之间。
    • 注意:你需要把撬棍伸到塑料盘下面,不要只伸到侧面。Google Home Mini是从底部打开的,需要先将这个橡胶塑料圆盘移除。
    Your Note information seems contradictory to your bulleted instruction. Recommend removing the note text and updating the step itself to say, “Use the medal spudger and place it between the housing and the adhered plastic base of the rubberized disc.“
    _TT_ - 回复
    Recommended to use a heat gun to soften the adhesive a bit. Using the spudger alone didn't work for me. Heat gun on lower power was good enough to get spudger underneath the plastic/rubber disk.
    JCPhoenix32 - 回复
  3. Google Home Mini 拆解: 步骤 3 中的图像 1,2 Google Home Mini 拆解: 步骤 3 中的图像 2,2
    • 现在在塑料圆盘下面移动撬棍,直到分离塑料圆盘底面所有的胶水。
    • 接下来,小心地剥开圆盘。
  4. Google Home Mini 拆解: 步骤 4 中的图像 1,1
    • 现在,移除4个螺丝钉
    • 4 x 6mm T6 螺丝钉
    • 如果螺丝钉上面有胶水的话直接用螺丝刀刺穿就可以拧了,不要清理胶水,否则一会儿塑料圆盘就粘不上了。
    If you don't want to reattach the rubber ‘foot’ or if you would prefer to use your own double-sided tape for easier future access you can carefully roll over just enough of one edge of the glue sticker to grab it and then carefully peel it and it should come off in one piece.
    dragon788 - 回复
    Can I cut around the screw holes in the base with an xacto knife/dremel/drill so I don’t have to peel off the plasticized rubber base? Does anyone have the dimensions and locations of the screw holes relative to the other base features so I can locate the screw holes and try cutting holes in the base in just those spots?
    Krishna Sethuraman - 回复
    Hmmmmm.....
    Bet that turned out a holy mess lol (Inside The Mind of a glue sniffer) let's drill electronics after size mic testing.. and ps the screw head is recessed if u were missing you'd be threw to the main board before u knew it. e fact that it's designed to sound best with all equipment intact.. why don't you spin some more majic Chrystal and grab a bunch of paint markers and put gang symbols of gangs you were or never be in and snap some selfys with you graffiti speaker with holes in it sitting off set cuz the rubber foots all tore up and ya you'll be a gangster as much as you think you are some kinda tech engineer on the cutting edge of electronics and your IQ test said it you don't need to try to be special princess you already are, cuz the tear down is shown like this because some special outside of the box forward thinker like YOU already Tried, Failed and became a FB Gangster and it was decided that this teardown is one of or the best method. So spooge it on the MINI bottom G.. DanKelly
    lonewolfkelly1978 - 回复
  5. Google Home Mini 拆解: 步骤 5 中的图像 1,3 Google Home Mini 拆解: 步骤 5 中的图像 2,3 Google Home Mini 拆解: 步骤 5 中的图像 3,3
    • 把设备翻过来后,你就可以轻轻地把织物上盖拿下来了。
    • 注意在把上盖拿下来前,先用撬棍把上盖下的FPC连接线拔下来。
    Suggested revision: “While keeping the top close to the base as in the picture, disconnect the ribbon cable from the connector with a spudger.”
    David Spalding - 回复
    My USB connector broke. Can I buy another one ?
    Nicolas Huray - 回复
    I’m looking for a USB connection replacement.
    Edmundo Guajardo - 回复
    the ribbon cable pulls straight back from the socket. I tried to pry up the cover/lock but this was not necessary (or apparently possible)
    Andrew Cooper - 回复
  6. Google Home Mini 拆解: 步骤 6 中的图像 1,3 Google Home Mini 拆解: 步骤 6 中的图像 2,3 Google Home Mini 拆解: 步骤 6 中的图像 3,3
    • 现在把上盖上另外4个螺丝钉拧下来。
    • 4 x 8mm T9 螺丝钉
  7. Google Home Mini 拆解: 步骤 7 中的图像 1,3 Google Home Mini 拆解: 步骤 7 中的图像 2,3 Google Home Mini 拆解: 步骤 7 中的图像 3,3
    • 现在用撬棍把扬声器的线拨下来。
    • 接下来,拧下另外4个螺丝钉。
    • 4x 9mm T6 螺丝钉。
  8. Google Home Mini 拆解: 步骤 8 中的图像 1,3 Google Home Mini 拆解: 步骤 8 中的图像 2,3 Google Home Mini 拆解: 步骤 8 中的图像 3,3
    • 现在拆下金属片,小心地用撬棍将主板抬起来。
    • 主板上有2个地方用胶水粘住了,但依然可以比较容易地取下来。
  9. Google Home Mini 拆解: 步骤 9 中的图像 1,3 Google Home Mini 拆解: 步骤 9 中的图像 2,3 Google Home Mini 拆解: 步骤 9 中的图像 3,3
    • 主板
    • 麦克风
    • 状态LED指示灯
由衷感谢以下译者:
de zh
100%
Phil McGill正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Norman Schleicher
于01/13/18注册
365 声望
撰写一个指南
21条评论
Sehr gute Anleitung. Fachlich korrekt(habe es selbst ausprobiert) und passende Bilder. Vielen Dank.
Regionaut - 回复
Do you know the resistance (ohm) of the speaker?
Bennet Heidekorn - 回复
Did you ever find this out? I know the home is 4ohm, presuming this is the same?
Barry Craig -
For anyone coming to this late, it is a 4ohm speaker.
Barry Craig -
Is it a 4 Ohm 3 Watt driver?
NÖME Technologys and Designs -
Uses a Texas Instruments TAS5720LRSMT amplifier IC which is rated at 20W @ 4 Ohm
Ed Reagan -
Thanks a lot !
Do you know if the mic on/off button cut directly the microphones or is it just an input for the chip ? (In that second case any software hack will be sufficient to listen the microphones even with the button on the off position… )
Agathe PINEL - 回复
Excellent first teardown guide, bravo!
David Spalding - 回复
Well not sure how but my Home Mini stopped working so I dismantled it completely as per the instructions, put it back together and my god it’s working perfectly. Thanks Ifixit and Norman.
Rod Hepburn - 回复
did you manage to know the specs of the hardwares plugged onto the motherboard?
erbern_0212 - 回复
Do you know the sound output? I guess it may has 2-5 watts amplifier, is it right?
ok100ho - 回复
I’ve seen youtube videos using a heatgun to soften the glue before using the spudger, which isn’t mentioned here. You say “move around with the spudger under the plastic plate until the adhesive has dissolved on the entire surface”, but how does a spudger dissolve the adhesive? Is this description missing application of a heat gun, or is the spudger heated?
Curious to know if heat is not needed to safely remove the rubber base.
Donovan Baarda - 回复
Is the fabric thermoformed over the top part?
Dylan Wiener - 回复
fix my google home mini because is broken with water or something
Gabriel's Vlog - 回复
What is the name (reference) of the small white connector (Step 7) used to connect the speaker to the board ?
UsulPaulMuad'Dib - 回复
Is there any way to replace the speaker part into google nest mini which more clarity sound and double bass ..
Amerta Dewata - 回复
Is it possible to somehow use an arduino or a raspberry pi to make the leds rgb?
Inara Hockert - 回复
my google mini is different i dont have the orange part to take off to expose the screws. i ddo see orange but its under the hard outer layer. perhaps i have another model or? its exactly the same except the screws are under the hard outer shell. help
Andrea Baker - 回复
Just had my speaker start saying the mic was muted when I hadn't touched the switch and it is set to ON. Flipping the switch back and forth only very temporarily helped. Took the bottom off per this guide to get access to the switch. Found even with the switch set to mic ON, there was ~1kΩ between the two pins that should be open circuit. Popped the metal cover of the switch itself off and found dendrite growth between the two terminals. Cleaned with isopropyl alcohol (rubbing alcohol) to remove build-up, added a small dab of dielectric grease (not necessary), and now 100% back to normal (full open circuit as expected). Thanks again iFixit!
Caleb Kelsay - 回复
I ripped the tip of the ribbon. How can I fix it?
Abdullah Collins - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 94
过去 30 天: 573
总计 65,085
