跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Garmin Nuvi 200,请使用我们的维修手册
  1. Garmin Nuvi 200 Teardown, The parts of the Garmin Nuvi 200: 步骤 1 中的图像 1,1
    • Top left: back casing
    • Top right: front casing
    • Middle left: speaker. Part ($29) and service at portatronics.com
    • Middle right: motherboard
    • Bottom left: battery. Part ($5.20) at amazon.com
    • Bottom right: LCD screen. Assembly kit ($49) at portatronics.com
  2. Garmin Nuvi 200 Teardown: 步骤 2 中的图像 1,2 Garmin Nuvi 200 Teardown: 步骤 2 中的图像 2,2
    • The Serial Number Strip is at the base of the device. Remove it to two expose two T5 Torx screws.
    • Using the T5 Torx screwdriver, remove the two T5 Torx screws.
  3. Garmin Nuvi 200 Teardown: 步骤 3 中的图像 1,3 Garmin Nuvi 200 Teardown: 步骤 3 中的图像 2,3 Garmin Nuvi 200 Teardown: 步骤 3 中的图像 3,3
    • Use care. Do no break apart the strip of orange tape that connects the LCD screen and motherboard (red box in third picture.)
    • Using the plastic opening tool, only at the bottom of the device, separate the back panel from the front panel.
  4. Garmin Nuvi 200 Teardown: 步骤 4 中的图像 1,2 Garmin Nuvi 200 Teardown: 步骤 4 中的图像 2,2
    • Use care. The glass on top of the screen is delicate.
    • Using the plastic opening tool, push apart the clasps holding the LCD screen in place.
    • Wedge the plastic opening tool between the LCD screen and the metal frame of the device.
  5. Garmin Nuvi 200 Teardown: 步骤 5 中的图像 1,2 Garmin Nuvi 200 Teardown: 步骤 5 中的图像 2,2
    • Hold the blue wire from its connector head.
    • Pull the connector head out of the outlet to unplug the speaker.
  6. Garmin Nuvi 200 Teardown: 步骤 6 中的图像 1,3 Garmin Nuvi 200 Teardown: 步骤 6 中的图像 2,3 Garmin Nuvi 200 Teardown: 步骤 6 中的图像 3,3
    • Using the Phillips #PH00 screwdriver remove the three screws that hold the motherboard in place.
    • Use Screwdriver bit #PH00 in IFixIt's Tool Kit to take out the three screws holding the motherboard in place.
  7. Garmin Nuvi 200 Teardown: 步骤 7 中的图像 1,2 Garmin Nuvi 200 Teardown: 步骤 7 中的图像 2,2
    • Peel the strip of orange tape from the white attachment bar on the motherboard.
    • This detaches the motherboard and LCD Screen (see second picture for blue box).
  8. Garmin Nuvi 200 Teardown: 步骤 8 中的图像 1,3 Garmin Nuvi 200 Teardown: 步骤 8 中的图像 2,3 Garmin Nuvi 200 Teardown: 步骤 8 中的图像 3,3
    • Remove the strip of orange tape from the LCD screen to detach the LCD screen from the front casing.
  9. Garmin Nuvi 200 Teardown: 步骤 9 中的图像 1,3 Garmin Nuvi 200 Teardown: 步骤 9 中的图像 2,3 Garmin Nuvi 200 Teardown: 步骤 9 中的图像 3,3
    • Prop the motherboard up.
    • Hold the red and green wires from the connector head.
    • Pull the connector head out of the outlet to detach the motherboard from the back casing.
  10. Garmin Nuvi 200 Teardown: 步骤 10 中的图像 1,2 Garmin Nuvi 200 Teardown: 步骤 10 中的图像 2,2
    • Use care. The back casing and battery are glued together. Do not puncture the battery.
    • Push the flat end of the spudger under the battery and separate the battery from the back casing.
  11. Garmin Nuvi 200 Teardown: 步骤 11 中的图像 1,2 Garmin Nuvi 200 Teardown: 步骤 11 中的图像 2,2
    • Using the Phillips #000 screwdriver remove the two screws holding the speaker in place.
    • Remove the speaker.
Kasey Gray
于10/28/13注册
206 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 40
总计 12,441
