跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的GEN 2 Wheelchair,请使用我们的维修手册
  1. GEN 2 Wheelchair Teardown, GEN 2 Wheelchair Teardown: 步骤 1 中的图像 1,3 GEN 2 Wheelchair Teardown, GEN 2 Wheelchair Teardown: 步骤 1 中的图像 2,3 GEN 2 Wheelchair Teardown, GEN 2 Wheelchair Teardown: 步骤 1 中的图像 3,3
    • Find a clean area to work in so every part can be accounted for.
  2. GEN 2 Wheelchair Teardown: 步骤 2 中的图像 1,3 GEN 2 Wheelchair Teardown: 步骤 2 中的图像 2,3 GEN 2 Wheelchair Teardown: 步骤 2 中的图像 3,3
    • Remove the footrest by unscrewing the lower bolt, using the 10 mm wrench.
    • Remove the upper bolt above the socket.
    • Slide out the footrest and unscrew the plate welded to the socket.
    • Slide the plate upward and off of the track to remove.
    • Untie the foot retention belt.
  3. GEN 2 Wheelchair Teardown: 步骤 3 中的图像 1,2 GEN 2 Wheelchair Teardown: 步骤 3 中的图像 2,2
    • Undo the seatbelt.
    • Remove the seat cushion by pulling it off of the velcro.
    • Remove the back padding by untieing the straps attached to the back pad.
  4. GEN 2 Wheelchair Teardown: 步骤 4 中的图像 1,1
    • Turn the wheelchair upside down and untie the plastic seat.
    • Remove the plastic seat support.
  5. GEN 2 Wheelchair Teardown: 步骤 5 中的图像 1,1
    • Locate the plastic cap on top of the caster wheels.
    • Place the 10mm wrench underneath the plastic cap and lift it up to remove.
  6. GEN 2 Wheelchair Teardown: 步骤 6 中的图像 1,2 GEN 2 Wheelchair Teardown: 步骤 6 中的图像 2,2
    • Remove the caster wheels by unscrewing the bolt under the cap with a 19 mm wrench.
    • Lift the wheelchair up to pull the caster wheels off.
    • Use caution: The metal sheath and the bearing of the caster wheel is not attached and may fall off upon removal.
  7. GEN 2 Wheelchair Teardown: 步骤 7 中的图像 1,1
    • Use a 1/2 inch socket wrench to unscrew bolts to remove the brakes.
    • Pull the brakes off.
  8. GEN 2 Wheelchair Teardown: 步骤 8 中的图像 1,2 GEN 2 Wheelchair Teardown: 步骤 8 中的图像 2,2
    • Remove the wheels by placing a 19 mm socket wrench on the inside of the wheel and unscrew the bolt.
    • Unscrew the bolt on the outside of the wheel by using a 19 mm socket wrench.
  9. GEN 2 Wheelchair Teardown: 步骤 9 中的图像 1,3 GEN 2 Wheelchair Teardown: 步骤 9 中的图像 2,3 GEN 2 Wheelchair Teardown: 步骤 9 中的图像 3,3
    • Unscrew all of the 10mm bolts on the frame using the 10 mm wrench (15 bolts total).
    • Separate the handle frame pieces from the metal side structure (2 bolts total).
    • Remove the bolts attaching the three support beams (4 bolts each, 12 bolts total).
  10. GEN 2 Wheelchair Teardown: 步骤 10 中的图像 1,1
    • Remove the bolt with the rubber cap that attaches the air pump to the center support on the bottom.
  11. GEN 2 Wheelchair Teardown: 步骤 11 中的图像 1,1
    • Congratulations! Your teardown is now complete. Make sure all of the parts are accounted for before storing or shipping.
Jennifer
于04/17/13注册
32 声望
撰写一个指南
团队
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G8
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 2,301
