跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Free Wheelchair Mission GEN 1,请使用我们的维修手册
  1. Free Wheelchair Mission GEN 1 Teardown, Remove Air Pump: 步骤 1 中的图像 1,2 Free Wheelchair Mission GEN 1 Teardown, Remove Air Pump: 步骤 1 中的图像 2,2
    • Start by finding the pump on the back of the wheelchair.
    • Remove the screw that holds the pump to the frame with a 10 mm wrench.
  2. Free Wheelchair Mission GEN 1 Teardown, Remove Footrest: 步骤 2 中的图像 1,1
    • To remove the footrest, turn it upside-down and use the 10 mm box wrench to take out all four of the screws.
  3. Free Wheelchair Mission GEN 1 Teardown, Remove Seat Cushion: 步骤 3 中的图像 1,1
    • Untie the four ties around the corners and back of the chair by pulling the strings.
    • Remove the cushion from the chair.
  4. Free Wheelchair Mission GEN 1 Teardown, Remove Brakes: 步骤 4 中的图像 1,1
    • Use the 10 mm box wrench to unscrew the two screws that hold the brake to the frame.
    • Remove the brake from the frame.
  5. Free Wheelchair Mission GEN 1 Teardown, Remove Wheel: 步骤 5 中的图像 1,1
    • Use a 19 mm socket wrench to unscrew the axle bolt.
    • The Free Wheelchair Mission Multi-Purpose Tool can be used in place of the 19 mm socket wrench
    • Use a 19 mm adjustable wrench (also known as a Crescent wrench) to prevent the nut from spinning.
    • Slide the wheel off the frame.
  6. Free Wheelchair Mission GEN 1 Teardown, Remove Axle Plates: 步骤 6 中的图像 1,3 Free Wheelchair Mission GEN 1 Teardown, Remove Axle Plates: 步骤 6 中的图像 2,3 Free Wheelchair Mission GEN 1 Teardown, Remove Axle Plates: 步骤 6 中的图像 3,3
    • Turn the chair around to see the two base plates that hold the axle to the back of the chair. There are two screws on each of the plates that connect the chair to the axle.
    • Hold the nut with a 10 mm wrench in one hand. In the other hand, use a wrench to remove the screw.
  7. Free Wheelchair Mission GEN 1 Teardown, Remove Front Frame and Castor Wheels: 步骤 7 中的图像 1,2 Free Wheelchair Mission GEN 1 Teardown, Remove Front Frame and Castor Wheels: 步骤 7 中的图像 2,2
    • Next you'll remove the screws that hold the back frame, chair, castor wheel, and front frame together. There is one screw on each side of the chair immediately above where the brakes are located.
    • Remove both of these screws using a 10 mm wrench.
    • Separate the front frame and and the castor wheel from the chair.
  8. Free Wheelchair Mission GEN 1 Teardown, Remove Chair: 步骤 8 中的图像 1,1
    • Remove the chair from the frame.
Mike Sevilla
于04/05/13注册
348 声望
创作了3篇指南
团队
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G7
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 1,560
