你所需要的
Fixing method: Adhesive
Tear apart the adhesive section by hand
Disassemble it by hand
If it is hard to take it off, you can use a knife cutting into the parting line to help
Fixing method: Screw-fixed
After the last step, the screws appear
5 screws in total
2 kinds of screw
Rotate the screwdriver counterclockwise
Use a knife or a "-" head screwdriver to cut into the parting line
It is a snap structure so it may require a bit of force to disassemble
This is also a snap structure. It requires more force to disassemble by hand
4 screws in total
It is an inclined plane, so just pull it slightly to take it off
Fix method: Snap structure
Peel it off by hand
This is the last disassembly step of the left earpiece. Most of the steps for the right earpiece are the same.
Peel it off slightly by hand
Peel off the rubber part
The screws and the sponge then appear
2 on each side
4 in total
Fixing method: Snap structure
After the last step, turn it over and the metal piece will drop out
8 categories are included
Sponge, Leather, Rubber, Screws, Metal, Plastic, adhesive components, electronic components
当重新组装你的设备时,请按照说明的相反顺序进行操作。
