跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Floppy Disk,请使用我们的维修手册
  1. Floppy Disk Teardown, Floppy Disk Teardown: 步骤 1 中的图像 1,2 Floppy Disk Teardown, Floppy Disk Teardown: 步骤 1 中的图像 2,2
    • The floppy disk has gone the way of the dinosaur.
    • Except for Google's lovable jumping dinosaur.
    • These disks might hold one or two photos at best; they probably won't hold much more though at only 2MB.
    • It's worth noting that today's photos taken can be upwards of 10MB on their own!
    • We liked skimmilk05's teardown so much (and his amazing attempt at his own teardown graphic) we supplied one of our own for this truly unique community contributed teardown. - iFixit Staff <3
  2. Floppy Disk Teardown, Removing the Cover: 步骤 2 中的图像 1,2 Floppy Disk Teardown, Removing the Cover: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Jimmy
    $7.95
    购买
    • Thin metal pieces are good places to start.
    • This one's so thin that you can bend it with a finger.
    • This one wasn't too hard, but if you're having trouble getting it up, a Jimmy comes in handy.
  3. Floppy Disk Teardown, Removing the Casing: 步骤 3 中的图像 1,3 Floppy Disk Teardown, Removing the Casing: 步骤 3 中的图像 2,3 Floppy Disk Teardown, Removing the Casing: 步骤 3 中的图像 3,3
    • With some careful prying, the entire lid pops right off.
    • You may need a spudger, metal spudger, Jimmy, or a combination of the three to get into the crack where the metal piece once was.
    • There are little pushpins holding the two halves together, but they were pulled apart during disassembly, easy as 1, 2, 3!
    • And we get a glimpse of what's inside! Spoiler alert: not much is there.
  4. Floppy Disk Teardown, The Spring: 步骤 4 中的图像 1,1
    • In cracking open the casing, we lost a tiny little spring.
    • Boing.
    • Boing.
    • Playtime's over. Best guess as to what it is? Keeping that metal piece over the tape inside.
  5. Floppy Disk Teardown, The Cleaning Pad: 步骤 5 中的图像 1,1
    • On the inside, we see a small pad, probably to clean the turning disk that's inside.
    • This one was pretty nasty. Eww.
    • This pad is glued into the casing with some tough adhesive; the manufacturer really didn't want this pad coming out on its own.
    • Aha!
    • The meat n' bones of the floppy disk, the disk itself!
    • Ever wondered why the floppy disk was called the "floppy" disk, even though it was in that hard plastic case? This is why.
  6. Floppy Disk Teardown, The Disk: 步骤 7 中的图像 1,2 Floppy Disk Teardown, The Disk: 步骤 7 中的图像 2,2
    • More floppy goodness.
    Any ideas how to reattach the centre metal ring due to adhesive going bad
    tanglebeans - 回复
  7. Floppy Disk Teardown, Wrap-up: 步骤 8 中的图像 1,1
    • It's a pretty simple device in all. Not much else to say here.
  8. Floppy Disk Teardown, Final Thoughts: 步骤 9 中的图像 1,2 Floppy Disk Teardown, Final Thoughts: 步骤 9 中的图像 2,2
    • Floppy Disk Repairability Score: 1 out of 10 (10 is the easiest to repair)
    • This antique technology has virtually no replacement parts.
    • Replacement of the tape or cleaning pads are impossible without breaking the case.
    • The cleaning pads are held on with tight adhesive, making replacement difficult.
    • Attempts to use heat to loosen adhesive may result in the case melting.
    • High susceptibility to magnets make this device very sensitive.
Seji the veggie
于02/09/15注册
1,986 声望
撰写一个指南
10条评论
Super cool! Haven't seen a floppy disk in forever.
Taylor Whitney - 回复
They are a tad old...haha
Seji the veggie -
This is amazeballs. Solid work!
Kay-Kay Clapp - 回复
"floppy goodness" -- so good
Julia - 回复
Great teardown! :)
Jeff Suovanen - 回复
Thanks! I tried...
Seji the veggie -
I've found that floppy disks make great coasters! On a serious note, actually got a call from a client last week asking me if I could make a floppy disk for him, as his work computer didn't have a floppy drive. He emailed me the program. Turns out it was for some sort of CNC or milling machine that still uses floppies. Never count out the old school equipment.
Gregory Hostiuck - 回复
Indeed! Neglect not.
Seji the veggie -
1. You forgot the little plastic tab in the corner that blocks writing if necessary.
2. Repairability 1 out of 10: are you serious? you just never used Scotch tape to tape two halves of the body together. Also, that thing works happily without the metal shutter.
damiracle - 回复
Come on man, everyone knows that scotch tape doesn't last more than a day. :)
Seji the veggie -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 61
总计 10,538
