跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Flipper Zero,请使用我们的维修手册
  1. Flipper Zero Teardown, Caution: 步骤 1 中的图像 1,1
    • Do not use alcohol or alcohol containing cleaners, tissues, wipes, or sanitizers on the acrylic window! It can permanently damage it.
    • The top shell, the IR cover and the acrylic window are one solid part and can't be disassembled. (They pop out with a bit of force but wont go back in as well without some sort of glue)
    • The Flipper Zero only uses two types of screws:
    • Long screw size is M1.7x8
    • Short screw size is M1.7x4
  2. Flipper Zero Teardown, Remove the microSD card: 步骤 2 中的图像 1,1
    • Eject the microSD card (if present) by pressing it with your fingernail.
  3. Flipper Zero Teardown, Remove the screws: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    购买
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
  4. Flipper Zero Teardown, Open the back cover: 步骤 4 中的图像 1,3 Flipper Zero Teardown, Open the back cover: 步骤 4 中的图像 2,3 Flipper Zero Teardown, Open the back cover: 步骤 4 中的图像 3,3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  5. Flipper Zero Teardown, Lift the NFC antenna: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    购买
    • The board with the NFC antenna is glued to the bottom cover with adhesive tape.
    • To remove the board, gently pry one of the edges of the board with a plastic pick to peel off the adhesive tape.
  6. Flipper Zero Teardown, Pull out the NFC antenna: 步骤 6 中的图像 1,2 Flipper Zero Teardown, Pull out the NFC antenna: 步骤 6 中的图像 2,2
    • Gently pull out the rest of the board.
  7. Flipper Zero Teardown, Unscrew the chassis: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    购买
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
  8. Flipper Zero Teardown, Seperate the chassis from the top cover: 步骤 8 中的图像 1,1
    • Take the chassis out of the case.
  9. Flipper Zero Teardown, Disconnect the battery: 步骤 9 中的图像 1,1
    • Disconnect the battery by prying the connector with a plastic pry tool and pulling it out.
    • Do not use a metal screwdriver when prying out battery connectors, if you do it may short the battery terminals and cause damage to the battery.
  10. Flipper Zero Teardown, Disconnect the ribbon cables: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to release the locks.
  11. Flipper Zero Teardown, Disconnect the ribbon cables: 步骤 11 中的图像 1,1
    • Once the connectors are unlocked, carefully pull out the ribbon cables.
  12. Flipper Zero Teardown, Unscrew the iButton board: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    购买
    • Unscrew the short screw holding the iButton board in place using a PH0 screwdriver.
  13. Flipper Zero Teardown, Remove the iButton board: 步骤 13 中的图像 1,1
    • Once the screw is removed, carefully remove the iButton board.
  14. Flipper Zero Teardown, Remove the cable from the iButton board: 步骤 14 中的图像 1,1
    在这个步骤中使用的工具:
    Flathead 1.5 mm Screwdriver
    $5.49
    购买
    • To disconnect the flat cable from the iButton board, use a flat screwdriver to carefully release the lock by pulling the latch up, then pulling gently on the ribbon cable.
  15. Flipper Zero Teardown, Remove the cable from the iButton board: 步骤 15 中的图像 1,1
    • Once the connector is unlocked, gently pull the cable out of the connector.
  16. Flipper Zero Teardown, Release the battery chassis: 步骤 16 中的图像 1,2 Flipper Zero Teardown, Release the battery chassis: 步骤 16 中的图像 2,2
    • To release the battery chassis, gently rock it back and forth while pulling the two parts apart.
  17. Flipper Zero Teardown, Remove the NFC RFID board: 步骤 17 中的图像 1,1
    • To remove the NFC RFID board, release it from the latches in the sequence shown.
  18. Flipper Zero Teardown, Remove the NFC RFID board: 步骤 18 中的图像 1,1
    • Release the board from the latches by pressing on the edge of the chassis near the specific latch in the specified sequence.
  19. Flipper Zero Teardown, Remove the vibration motor: 步骤 19 中的图像 1,2 Flipper Zero Teardown, Remove the vibration motor: 步骤 19 中的图像 2,2
    • Take out the vibration motor.
  20. Flipper Zero Teardown, Unscrew the lace mount: 步骤 20 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    购买
    • To remove the lace mount, use a PH0 screwdriver to unscrew the short screw that is securing it in place.
  21. Flipper Zero Teardown, Remove the lace mount: 步骤 21 中的图像 1,1
    • Remove the lace mount from the chassis.
  22. Flipper Zero Teardown, Remove the battery: 步骤 22 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • The battery is attached to the chassis with double-sided tape. To remove it, use a plastic pick to gently peel the battery off the chassis.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  23. Flipper Zero Teardown, Remove the battery: 步骤 23 中的图像 1,2 Flipper Zero Teardown, Remove the battery: 步骤 23 中的图像 2,2
    • Remove the battery from the chassis.
  24. Flipper Zero Teardown, Remove the ribbon cable: 步骤 24 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a plastic pick to lift the latch up to unlock the connector.
  25. Flipper Zero Teardown, Remove the ribbon cable: 步骤 25 中的图像 1,1
    • Pull the flat cable out.
  26. Flipper Zero Teardown, Unscrew the the button chassis: 步骤 26 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    购买
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
  27. Flipper Zero Teardown, Seperate the button chassis: 步骤 27 中的图像 1,1
    • To disconnect the button chassis and the board, press the latch on the side shown below.
  28. Flipper Zero Teardown, Remove the button chassis: 步骤 28 中的图像 1,2 Flipper Zero Teardown, Remove the button chassis: 步骤 28 中的图像 2,2
    • Remove the button chassis.
  29. Flipper Zero Teardown, Disconnect the screen: 步骤 29 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock.
  30. Flipper Zero Teardown, Disconnect the screen: 步骤 30 中的图像 1,1
    • Remove the cable from the board.
  31. Flipper Zero Teardown, Desolder the screen: 步骤 31 中的图像 1,1
    • To remove the screen you need to desolder two contacts.
    • Be careful during this step not to accidentally melt or desolder other nearby components.
  32. Flipper Zero Teardown, Remove the buttons: 步骤 32 中的图像 1,1
    • To remove the buttons you need to release the latches.
    • OK
    • D-pad
    • Back
    • The central button (OK) is removed after the navigation button (D-pad)
  33. Flipper Zero Teardown, Remove the buttons: 步骤 33 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    购买
    • Release the latches with a flat screwdriver. You need to be careful with the springs under the buttons.
  34. Flipper Zero Teardown, Remove the light guide: 步骤 34 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    购买
  35. Flipper Zero Teardown, Remove the light guide: 步骤 35 中的图像 1,2 Flipper Zero Teardown, Remove the light guide: 步骤 35 中的图像 2,2
    • Pull the light guide out from the inside of the chassis.
  36. Flipper Zero Teardown, Finish: 步骤 36 中的图像 1,1
    • Here you can see all the parts laid out together.
13条评论
I'd say, that long screws requires PH1 screwdriver.
Evge Key - 回复
Agree with Evge, when I read "PH0" I picked mine but they wouldn't quite fit. I had to use a PH1 (1.2 to be exact, according to toolset casing) to be able to unscrew the chasis and get to the battery (I had to only remove and plug back the battery cable to fix my problem)
João Ciocca - 回复
Careful with those screws. They are not great quality and strip easily.
andy cooper - 回复
Yeah, I have run into the same issue. The screw securing my IR/iButton board sheered in half! I cant remove the bottom part since its flush with the socket, but the board seems to be alright without it and is still in place since the chassis supports it. I still need to find a way to get it out :)
SkidFace -
Do you know what kind of these screws are?
Gugo - 回复
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 227
过去 30 天: 1,085
总计 37,520
