跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Fitbit Zip,应参考我们的维修指南
  1. Fitbit Zip Teardown, Fitbit Zip Teardown: 步骤 1 中的图像 1,3 Fitbit Zip Teardown, Fitbit Zip Teardown: 步骤 1 中的图像 2,3 Fitbit Zip Teardown, Fitbit Zip Teardown: 步骤 1 中的图像 3,3
    • Use your iFixit Pro Tech Knife to slice and pry the different colored front and rear cases apart, as shown
  2. Fitbit Zip Teardown: 步骤 2 中的图像 1,2 Fitbit Zip Teardown: 步骤 2 中的图像 2,2
    • Remove the logic board/display assembly from the rear case
  3. Fitbit Zip Teardown: 步骤 3 中的图像 1,2 Fitbit Zip Teardown: 步骤 3 中的图像 2,2
    • Use your knife to slice off the bottom edge of the sticker found here on the rear of the board
  4. Fitbit Zip Teardown: 步骤 4 中的图像 1,3 Fitbit Zip Teardown: 步骤 4 中的图像 2,3 Fitbit Zip Teardown: 步骤 4 中的图像 3,3
    • Use a spudger to gently pry the display away from the logic board
    • Pry softly in each corner of the display, under the black frame
  5. Fitbit Zip Teardown: 步骤 5 中的图像 1,1
    • Seems to be it. The display doesn't appear to be separable from the logic board, sadly, making repairability completely out of the question.
Nathanael
于02/03/14注册
977 声望
创作了2篇指南
团队
Beautiful Savior Lutheran Church Beautiful Savior Lutheran Church 的会员
Business
1 名成员
创作了3篇指南
2条评论
The display can be separated from the logic board, just pull it free from the logic board connector.
Yuri Silkin - 回复
My fitbit zip came apart at the seams. I decided to go ahead and clean the screen off since it was coming apart already and the screen looked dusty. Any ideas on how to put it back together? I goes back together and when I hold it everything functions, but I can't get it to stay together. Silicone? Glue? Any suggestions?
sweeney todd - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 2,292
