跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Fender Champion 600,请使用我们的维修手册
  1. Fender Champion 600 Teardown, Fender Champion 600 Teardown: 步骤 1 中的图像 1,1
    • WARNING: First of all disconnect an amp from the power outlet!
    • Please be careful - Tube amps can hold a serious amount of electrical charge that can cause injuries or even death. Avoid touching any wires or contacts with your bare hands or instruments that have no reliable insulation.
  2. Fender Champion 600 Teardown: 步骤 2 中的图像 1,3 Fender Champion 600 Teardown: 步骤 2 中的图像 2,3 Fender Champion 600 Teardown: 步骤 2 中的图像 3,3
    • Let's start by removing the rear chassis screws. All of the screws we are going to deal with work nicely with a PH2 bit.
    • Then remove two side screws that also hold the amp chassis in place. Those are 4 x 30 mm btw.
  3. Fender Champion 600 Teardown: 步骤 3 中的图像 1,1
    • Below the chassis you'll find 4 more phillips screws holding a rear cover in place - remove them as well.
  4. Fender Champion 600 Teardown: 步骤 4 中的图像 1,2 Fender Champion 600 Teardown: 步骤 4 中的图像 2,2
    • Now it's time to remove the nuts on the input jacks and our broken volume pot - I used pliers to do that, but it is advisable to use a small adjustable wrench, combination wrench, or socket in order to avoid any unwanted scratches or damage.
  5. Fender Champion 600 Teardown: 步骤 5 中的图像 1,2 Fender Champion 600 Teardown: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Next let's remove the volume knob - you'll need a flat 2.5 bit for that. Carefully insert the bit into the hole on the rear side of the knob to undo a tiny screw inside of it.
    • That's it - chassis is free 👍.
    • Hint: use a plastic tray or a magnetic mat to safely store all of those screws and nuts. You can even write where all those parts come from.
  6. Fender Champion 600 Teardown: 步骤 6 中的图像 1,2 Fender Champion 600 Teardown: 步骤 6 中的图像 2,2
    • Slightly lift it up and pull towards you with just a hand to access the internals.
    • That's it - the amp's chassis is right in front of you.
    • Well done 👍
in_sympathy
于07/01/13注册
817 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 661
