跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Seagate Expansion,请使用我们的维修手册
  1. Expansion Teardown, Open the cover: 步骤 1 中的图像 1,1
    • Using a flat head screwdriver or plastic tool
  2. Expansion Teardown: 步骤 2 中的图像 1,1
    • Remove the cover
  3. Expansion Teardown: 步骤 3 中的图像 1,1
    • Remove the drive from the case
  4. Expansion Teardown: 步骤 4 中的图像 1,1
    • Peel back the shielding
  5. Expansion Teardown: 步骤 5 中的图像 1,1
    • Remove the Screw with the #02 screw driver
  6. Expansion Teardown: 步骤 6 中的图像 1,2 Expansion Teardown: 步骤 6 中的图像 2,2
    • Separate the adapter form the sata port
Dan
于02/18/19注册
4,261 声望
创作了9篇指南
2条评论
Hello,
I’d like to know if it’s possible to swap in another bigger NAS drive, as I keep my hard drive connected and it might be more durable.
Thank you !
Léana Jiang - 回复
This does appear to be a semi-destructive method. In the picture under step 2, you can see the series of plastic brackets on the cover are snapped. See my pictures here
I had difficulty finding a spot to pry up from. There are 4 lips around the cover that should make it easier. See pics.
Derick Roy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 74
总计 3,889
