你所需要的
The front of the device has a solar panel and a speaker grill.
The only obvious screws are the battery cover and the back.
Removing the battery shows a standard form factor.
If you're looking for a replacement, I've got you.
Pulling the power board away harder allows it to bend
here, we can see the underside, and how it REALLY works.
We can also see the hand crank generator on the bottom
to the right, is the USB and audio board. There is a ribbon cable connecting it, and it isn't user removable. :(
The power board and the main board are also user-inseparable :(
To wrap it up, we saw examples of both good and bad repairability, as all the circuit board are inseparable, but the battery and other components that may break more easily are connected by a standard port.
All the screws, no matter how big or small, were standard Phillips Head, and not some weird GameBit screw. (Looking at you, Nintendo!)
It's significantly better than most devices out there, but not perfect. It's great for most consumers, unless you want to replace a specific circuit board.
