跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Space Heater,请使用我们的维修手册
  1. Essential Home HC-409 Teardown, Removed protective grill: 步骤 1 中的图像 1,3 Essential Home HC-409 Teardown, Removed protective grill: 步骤 1 中的图像 2,3 Essential Home HC-409 Teardown, Removed protective grill: 步骤 1 中的图像 3,3
    • Remove the grill from corner to corner.
  2. Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: 步骤 2 中的图像 1,2 Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: 步骤 2 中的图像 2,2
    • Carefully remove the screws and place them aside.
  3. Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: 步骤 3 中的图像 1,3 Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: 步骤 3 中的图像 2,3 Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: 步骤 3 中的图像 3,3
    • As seen in the pictures, set the screwdriver on the edge of the cover and pry it out.
  4. Essential Home HC-409 Teardown, Remove safety sticker: 步骤 4 中的图像 1,2 Essential Home HC-409 Teardown, Remove safety sticker: 步骤 4 中的图像 2,2
    • Remove sticker in order to open the plastic casing of the heater.
  5. Essential Home HC-409 Teardown, Pry the product in half: 步骤 5 中的图像 1,2 Essential Home HC-409 Teardown, Pry the product in half: 步骤 5 中的图像 2,2
    • Slowly and carefully pry the plastic casing.
  6. Essential Home HC-409 Teardown, Remove the switch: 步骤 6 中的图像 1,2 Essential Home HC-409 Teardown, Remove the switch: 步骤 6 中的图像 2,2
    • Apply pressure onto the sides of the switch while pushing it outwards.
  7. Essential Home HC-409 Teardown, Remove fan: 步骤 7 中的图像 1,3 Essential Home HC-409 Teardown, Remove fan: 步骤 7 中的图像 2,3 Essential Home HC-409 Teardown, Remove fan: 步骤 7 中的图像 3,3
    • Unscrew the four screws located in the rear of the device. Remove the fan.
Garland Poon
于04/03/12注册
126 声望
撰写一个指南
团队
Cal Poly, Team 14-8, Forte Spring 2012 Cal Poly, Team 14-8, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G8
5 名成员
创作了17篇指南
一条评论
I keep having problems with that little part that looks like a pen cap - white plastic. Is it a connector ou a fuse?
Cristina S - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 1,447
