跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Dual USB Connector,请使用我们的维修手册
  1. MSI Dual USB Port Bracket Teardown, MSI Dual USB Port Bracket Teardown: 步骤 1 中的图像 1,1
    • This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
    • These connectors plug into the USB headers on the motherboard.
  2. MSI Dual USB Port Bracket Teardown: 步骤 2 中的图像 1,2 MSI Dual USB Port Bracket Teardown: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Phillips #1 Screwdriver
    $5.49
    购买
    • Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
    • On the bottom of the circuit board, the pins that hold its components can cut skin.
    • The two USB 2.0 ports.
    • The four LED lights, which light up depending on the activity of the USB ports.
  3. MSI Dual USB Port Bracket Teardown: 步骤 3 中的图像 1,1
    • Raise the three connectors from the case and it's out!
    • The connectors highlighted in red lead to the wires that connect the bracket to the motherboard.
    • The two USB ports.
    • The LED activity lights.
samhnri
于04/07/10注册
415 声望
创作了2篇指南
一条评论
Why does it need its owe usb header just for the LED's.
Rick Acker - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 55
总计 7,821
