简介
Guide to show how to tear down the display assembly from a 2013 MacBook Pro 15”
**I performed this teardown on a display assembly that already had cracked glass and a broken LCD and did not test it afterward.**
Loosen the adhesive between the hinge cover and screen by inserting an opening pick and sliding it across
Take a Jimmy (or similar tool) and pry up one corner of the hinge cover, and then insert an Opening Pick (or similar tool) where the Jimmy was
Repeat the same process with the other side
Now you should have one Opening Pick on each side of the hinge cover
Roll the hinge cover toward the screen to free the clips nearest to the glass
The clips are put back in place by first lining up the little pin with the hole on the hinge cover
Then, push it up and back into its place
