跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
  1. Dell Quietkey SK-8000 Keyboard Teardown, Remove Back Plastic Body: 步骤 1 中的图像 1,2 Dell Quietkey SK-8000 Keyboard Teardown, Remove Back Plastic Body: 步骤 1 中的图像 2,2
    • Flip the keyboard over to expose 8 screws.
    • Use a Phillips screwdriver to unscrew and remove each screw.
  2. Dell Quietkey SK-8000 Keyboard Teardown: 步骤 2 中的图像 1,2 Dell Quietkey SK-8000 Keyboard Teardown: 步骤 2 中的图像 2,2
    • Lift the keyboard upward from the bottom.
    • Do not pull too hard when lifting the base. Be careful not to destroy the wires connecting to the base of the keyboard.
    • Use a Phillips screwdriver to remove the remaining ten screws on the aluminum plate.
  3. Dell Quietkey SK-8000 Keyboard Teardown, Completion: 步骤 3 中的图像 1,3 Dell Quietkey SK-8000 Keyboard Teardown, Completion: 步骤 3 中的图像 2,3 Dell Quietkey SK-8000 Keyboard Teardown, Completion: 步骤 3 中的图像 3,3
    • Carefully lift each part out. Each part should lift out very easily after the screws are removed.
  4. Dell Quietkey SK-8000 Keyboard Teardown, Siltek Chip Reveal: 步骤 4 中的图像 1,1
    • The keyboard controller is seen to be a Siltek R4462.
Ion
于09/29/15注册
479 声望
创作了3篇指南
团队
Cal Poly, Team 10-5, Green Fall 2015 Cal Poly, Team 10-5, Green Fall 2015 的会员
CPSU-GREEN-F15S10G5
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 987
