跳转到主内容
Dell Latitude 7420 Keyboard Replacement/Teardown
你所需要的
  1. Dell Latitude 7420 Keyboard Replacement/Teardown, Remove backplate: 步骤 1 中的图像 1,2 Dell Latitude 7420 Keyboard Replacement/Teardown, Remove backplate: 步骤 1 中的图像 2,2
    • remove 8x screws with PH1 Screwdriver
    • Use finger nail or operning pick between backplate and frame at the top of the device
  2. Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect battery: 步骤 2 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect battery: 步骤 2 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect battery: 步骤 2 中的图像 3,3
    • remove battery connector by pulling up. make sure the pulling strap is turned upwards
    • remove 5x screws with PH1
    • these are longer, do not mix them up!
  3. Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect speaker cable: 步骤 3 中的图像 1,2 Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect speaker cable: 步骤 3 中的图像 2,2
    • remove speaker cable by pulling towards yourself horizontally
    • lift out the battery vertically.
  4. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect ribbon cables: 步骤 4 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect ribbon cables: 步骤 4 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect ribbon cables: 步骤 4 中的图像 3,3
    • open ribbon cable connectors by lifting up and away from you the black securing latch
    • carefully lift up ribbon cables and pull towards yourself
  5. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect headphone jack daughter board: 步骤 5 中的图像 1,1
    • Insert wisdom here.
  6. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect fan: 步骤 6 中的图像 1,1
    • pull horizontally to the rigt
  7. Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 步骤 7 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 步骤 7 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 步骤 7 中的图像 3,3
    • Use JIS00 or J00
    • display connector
    • wifi antenna connector
  8. Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 步骤 8 中的图像 1,2 Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: 步骤 8 中的图像 2,2
    • use JIS00 or J00
    • unscrew connector plate
  9. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect cables: 步骤 9 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect cables: 步骤 9 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect cables: 步骤 9 中的图像 3,3
    • lift upwards vertically
    • pull out horizontally away from you
  10. Dell Latitude 7420 Keyboard Replacement/Teardown, remove heat sink: 步骤 10 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove heat sink: 步骤 10 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove heat sink: 步骤 10 中的图像 3,3
    • remove 6x screws using PH1
    • remove cable sticker from heat sink
    • if the thermal paste has dried out the heat sink can be stuck on. carefully wiggle it horizontally until you can lift it up vertically
  11. Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard screws: 步骤 11 中的图像 1,1
    • use PH1 for 2x mobo screws
  12. Dell Latitude 7420 Keyboard Replacement/Teardown, remove USB C screws: 步骤 12 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove USB C screws: 步骤 12 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove USB C screws: 步骤 12 中的图像 3,3
    • remove 4x USB Screws with PH1
  13. Dell Latitude 7420 Keyboard Replacement/Teardown, USB C daughter board screws: 步骤 13 中的图像 1,2 Dell Latitude 7420 Keyboard Replacement/Teardown, USB C daughter board screws: 步骤 13 中的图像 2,2
    • remove 2x with PH1
  14. Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard: 步骤 14 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard: 步骤 14 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard: 步骤 14 中的图像 3,3
    • start on the right side at the USB C daughter board.
    • lift up the motherboard where the fan used to be
    • you should be able disconnect the daughterboard and mother board
    • the USB C port on the left might be tight. Use your fingers to slightly bend the laptop casing outward to the left above the usb c port
    • lift out the motherboard vertically
    • lift out USB C daughter board vertically. use the frame bending trick if necessary
  15. Dell Latitude 7420 Keyboard Replacement/Teardown, remove headphone jack daughter board: 步骤 15 中的图像 1,1
    • remove 1x screw with PH1
    • lift out daughter board vertically
  16. Dell Latitude 7420 Keyboard Replacement/Teardown, unstick ribbon cables: 步骤 16 中的图像 1,2 Dell Latitude 7420 Keyboard Replacement/Teardown, unstick ribbon cables: 步骤 16 中的图像 2,2
    • carefully unstick glued on ribbon cables. use are card and pull up at 45° angle
    • no need to remove headphone jack cable
    • disconnect ribbon cable
    • be extremly careful not to pull at bends in the ribbon cables
  17. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect keyboard ribbon cables: 步骤 17 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect keyboard ribbon cables: 步骤 17 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect keyboard ribbon cables: 步骤 17 中的图像 3,3
    • open connector as usual
    • the smaller ribbon cable has a different securing mechanism, look at the second image. it is opend from the other side
    • open connector from smaller ribbon cable at the white flap. NOT on top of the ribbon cable!
    • pull out ribbon cables
  18. Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard backplate screws: 步骤 18 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard backplate screws: 步骤 18 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard backplate screws: 步骤 18 中的图像 3,3
    • use JIS00 or J00 to remove 19x screws
    • go around perimeter of the backplate in a orderly fashion when removing the screws to not miss any
  19. Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard with backplate: 步骤 19 中的图像 1,2 Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard with backplate: 步骤 19 中的图像 2,2
    • lift up keyboard vertically
    • be careful: ribbon cables might be sticky
  20. Dell Latitude 7420 Keyboard Replacement/Teardown, removing keyboard from backplate: 步骤 20 中的图像 1,3 Dell Latitude 7420 Keyboard Replacement/Teardown, removing keyboard from backplate: 步骤 20 中的图像 2,3 Dell Latitude 7420 Keyboard Replacement/Teardown, removing keyboard from backplate: 步骤 20 中的图像 3,3
    • use PH1 to unscrew backplate from front of keyboard
  21. Dell Latitude 7420 Keyboard Replacement/Teardown, clean CPU and Heat Sink: 步骤 21 中的图像 1,2 Dell Latitude 7420 Keyboard Replacement/Teardown, clean CPU and Heat Sink: 步骤 21 中的图像 2,2
    • remove old thermal paste using isopropyl alcohol and a cloth
    • apply new thermal paste
  22. Dell Latitude 7420 Keyboard Replacement/Teardown, backplate: 步骤 22 中的图像 1,1
    • keyboard backplate
    • when you are done with reassembly do not panic, the first boot takes a little longer after disconnecting the battery
    • after reassembly press inbetween keyboard keys to klick together backplate and notebook frame
结论
3等其他人完成本指南。
fixer
于07/05/16注册
862 声望
创作了3篇指南
2条评论
Steps 10 and 13 are not necessary (motherboard could be removed together with a head sink)
Alex - 回复
After following this very useful guide my new keyboard was not working, when you reconnect all the ribbon cable take some time to reconnect them better then I have done :-D
If something is not working double check the ribbon cables connection before doing anything else.
daniele - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 48
过去 30 天: 215
总计 3,619
