跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Dell Inspiron 1750,请使用我们的维修手册
  1. Dell Inspiron 1750 Teardown, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 1750 Teardown, Battery: 步骤 1 中的图像 2,2
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Teardown: 步骤 2 中的图像 1,2 Dell Inspiron 1750 Teardown: 步骤 2 中的图像 2,2
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Teardown, Dell Inspiron 1750 Teardown: 步骤 3 中的图像 1,1
    • Separate the screws by size and head type. Be sure to keep them in a safe place.
    • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
    • Remove the two 2mm Phillips #0 screws from the hard drive port.
  4. Dell Inspiron 1750 Teardown: 步骤 4 中的图像 1,3 Dell Inspiron 1750 Teardown: 步骤 4 中的图像 2,3 Dell Inspiron 1750 Teardown: 步骤 4 中的图像 3,3
    • Keep your hand pressed firmly on the back panel to prevent it from falling.
    • Flip the laptop over horizontally and open up the lid.
    • Insert the tip of the plastic opening tool into the upper left corner of the panel.
    • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
    • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
    • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
  5. Dell Inspiron 1750 Teardown: 步骤 5 中的图像 1,3 Dell Inspiron 1750 Teardown: 步骤 5 中的图像 2,3 Dell Inspiron 1750 Teardown: 步骤 5 中的图像 3,3
    • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
    • Locate the small black latch attached to blue tape.
    • Lift the small latch with your finger and pull the blue tape from its port.
    • Slide the keyboard away from the mousepad and set it aside.
  6. Dell Inspiron 1750 Teardown: 步骤 6 中的图像 1,3 Dell Inspiron 1750 Teardown: 步骤 6 中的图像 2,3 Dell Inspiron 1750 Teardown: 步骤 6 中的图像 3,3
    • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Locate the three wires in the top left corner of the metal panel.
    • Use the spudger to push the two cables out of their ports.
    • Pull the blue tab directly up to remove middle wire.
  7. Dell Inspiron 1750 Teardown: 步骤 7 中的图像 1,2 Dell Inspiron 1750 Teardown: 步骤 7 中的图像 2,2
    • Remove the three 1mm Phillips #00 screws on the metal plate.
    • Lift the black cover and slide the blue tab away from the cover.
  8. Dell Inspiron 1750 Teardown: 步骤 8 中的图像 1,3 Dell Inspiron 1750 Teardown: 步骤 8 中的图像 2,3 Dell Inspiron 1750 Teardown: 步骤 8 中的图像 3,3
    • Gently remove the three grey wires from the metal tabs.
    • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
    • Gently lift off the top metal panel.
附加文件
Jordan Nedbailo
于04/07/14注册
687 声望
创作了2篇指南
团队
Cal Poly, Team 6-3, Forte Spring 2014 Cal Poly, Team 6-3, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G3
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 28
总计 20,259
