跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
  1. Dell 48x IDE Internal CD-ROM Drive Teardown, Take off the plate on the top: 步骤 1 中的图像 1,1
    • Unscrew the top four screws.
    • Make sure that you don't mix up the screws.
    • They are different and you don't want to use the wrong screws.
    • Why would they do that?
  2. Dell 48x IDE Internal CD-ROM Drive Teardown, Actually take off the plate: 步骤 2 中的图像 1,1
    • Take off the plate that you unscrewed last step
    • Put all the parts that you had taken off on the side so you do not lose them
  3. Dell 48x IDE Internal CD-ROM Drive Teardown, More Screws: 步骤 3 中的图像 1,1
    • Unscrew the four screws on the next plate.
  4. Dell 48x IDE Internal CD-ROM Drive Teardown: 步骤 4 中的图像 1,1
    • 4- take off the top plate by lifting the back up and lightly pulling up.
    • the picture to the left is what it looks like after you take the plate off.
  5. Dell 48x IDE Internal CD-ROM Drive Teardown: 步骤 5 中的图像 1,1
    • 5-flip over and push the side tabs in and lift the bottom piece off (it might be hard to do but try not to force it off).
  6. Dell 48x IDE Internal CD-ROM Drive Teardown: 步骤 6 中的图像 1,1
    • 6-push piece down and slide the disk piece out.
  7. Dell 48x IDE Internal CD-ROM Drive Teardown: 步骤 7 中的图像 1,1
    • 7-what is would look like.
  8. Dell 48x IDE Internal CD-ROM Drive Teardown: 步骤 8 中的图像 1,1
    • 8-unscrew the three screws on the spin piece.
  9. Dell 48x IDE Internal CD-ROM Drive Teardown: 步骤 9 中的图像 1,1
    • 9- unclip the chip in the front/back then lightly lift the piece up.
    • to put this device back together just do the steps backwards, nothing is hard to do.
    • be cautious because there are wires under the chip do don't pull hard or you are going to break it.
Brandon Frise
于09/14/15注册
45 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 13
总计 1,513
