跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Computer Hardware,请使用我们的维修手册
  1. D-Link 7-Port USB 2.0 HUB Teardown, Box: 步骤 1 中的图像 1,2 D-Link 7-Port USB 2.0 HUB Teardown, Box: 步骤 1 中的图像 2,2
    • D-Link 7-Port USB 2.0 HUB Model No.: DUB-H7 H/W Ver.: C1 UPC Code: 790069252389 Box
  2. D-Link 7-Port USB 2.0 HUB Teardown, Box contents: 步骤 2 中的图像 1,2 D-Link 7-Port USB 2.0 HUB Teardown, Box contents: 步骤 2 中的图像 2,2
    • Charger
    • USB cable
    • To open the USB HUB there are only 4 screws below the two pads.
Juan
于11/03/14注册
138 声望
创作了2篇指南
5条评论
Anyone can tell what is the output voltage on this ? Mine shows 4.88V and I don't know if I should return it or not. My USB devices seem unstable.
adrianTNT - 回复
I returned this low performance hub. But the USB spec says that voltage should be 5.00±0.25 V. So, voltage may not be the issue. If the device works correctly when directly connected to the computer, then just return the USB HUB, and upload a video (on youtube or somewhere else) so people can see the problem and not buy this low performance USB HUB.
If you need a high performance USB HUB just get this:
http://plugable.com/products/usb2-hub-ag...
Juan -
These hubs have been better than the previous version, but only in that the two right hand ports are capable of fast charging. Almost all devices benefit from 2.1 amp fast charging now. As for reliability, they suck just as much as every other stupid USB sharing device.
Kelly - 回复
Thanks for this! But I'm confused: is this single TT or multi TT?
samulialapuranen - 回复
Can anyone tell me what a good DVD burner I can buy to burn copy write disk
tony brookshire - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 67
总计 6,482
