跳转到主内容
简介
Tearing down a Cyclops Helios headlamp. Both hardware identification and functionality for the device are discussed.
这个拆解是不是维修指南。 要维修你的的Cyclops Helios,请使用我们的维修手册
  1. Power off Cyclops Helios before tearing down by pushing the black button until the LEDs no longer emit visible light.
    • Power off Cyclops Helios before tearing down by pushing the black button until the LEDs no longer emit visible light.
    • Black button - circled in red
  2. Using two hands, carefully separate the front panel and back panel of the Cyclops Helios. Front panel - boxed in red Back panel - boxed in blue
    • Using two hands, carefully separate the front panel and back panel of the Cyclops Helios.
    • Front panel - boxed in red
    • Back panel - boxed in blue
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Use a Phillips head screwdriver to remove two screws from the front panel. The two screws fasten the outer enclosure with the inner electronics of the front panel.
    • Use a Phillips head screwdriver to remove two screws from the front panel.
    • The two screws fasten the outer enclosure with the inner electronics of the front panel.
  5. Within the enclosure of the front panel there is a clear plastic lens, and plastic button insert. Both are removable. Clear plastic lens - boxed in red Plastic button insert - circled in blue
    • Within the enclosure of the front panel there is a clear plastic lens, and plastic button insert. Both are removable.
    • Clear plastic lens - boxed in red
    • Plastic button insert - circled in blue
  6. The inner electronics of module of the front panel includes a parabolic mirror, circuit board, and battery holder. Circuit board - boxed in blue Parabolic mirror - boxed in red
    • The inner electronics of module of the front panel includes a parabolic mirror, circuit board, and battery holder.
    • Circuit board - boxed in blue
    • Parabolic mirror - boxed in red
    • Battery holder - boxed in green
  7. Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder. Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder.
    • Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder.
Shaun Koide
于2013年11月14日注册
161 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 627
