简介
It’s time to stop loafing around and eat more crepes! The CucinaPro Cordless Crepe Maker allows consumers to cook crepes using a dipping plate that doubles as a cooking surface. The device powers through standard household electric supplies of 110-120V and 60Hz. Easy to use and relatively durable, it is a perfect way to introduce oneself to French cuisine. With that said, Bon Appetit!
你所需要的
精选文档
The CucinaPro crepe maker has two main components: a heating body and a power base.
Lift dipping pan from the plastic casing.
The two wires connected to the black connector transfer the AC power from the base to the heating coil underneath the pan surface.
White sleeves surround the wires, protecting them from heat damage.
The black connector also holds a grounding strip not connected to a wire.
Unscrew #1-20x6mm screw on black temperature sensor to reveal a gooey substance between sensor and the metal undercoating of the heating surface
While the coil heats and the heating surface is below optimal cooking temperature, power enters the coil and turns on the LED.
Upon reaching the optimal temperature, the power to the coil shuts off and the LED turns off, indicating the crepe is done.
CucinaPro Cordless Crepe Maker earns a 8 out of 10 on our repairability scale (10 is the easiest to repair).
The Crepe Maker is easy to use and handle; the overall system is relatively light.
Temperature sensor made it easy to know when the crepe was done cooking.
Dipping plate was an effective way to put crepe batter on plate.
It is easy for batter to get in between the crevices of the device.
There is no easy way to clean the device.
Surface area of the dipping plate is relatively small.
