跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的MP3 Player,请使用我们的维修手册
  1. Cowon iAudio 7 8GB Teardown, Cowon iAudio 7 8GB Teardown: 步骤 1 中的图像 1,1
    • The device in original condition.
  2. Cowon iAudio 7 8GB Teardown: 步骤 2 中的图像 1,1
    • Removed the back of the case and the PCB screws. I had to drill open one of the case screws as it was stuck.
  3. Cowon iAudio 7 8GB Teardown: 步骤 3 中的图像 1,2 Cowon iAudio 7 8GB Teardown: 步骤 3 中的图像 2,2
    • All parts disassembled. Second photo shows back side of the PCB.
    • As we can see, the device contains two Samsung 4GB flash chips along with a K4M28163PH-BG75 memory controller.
    • A Telechips TCC771L as main CPU.
    • A PCF50606HN battery/power management chip.
[deleted]
于03/24/14注册
210 声望
撰写一个指南
3条评论
2011music my songs
Tong Thao - 回复
Hi! Could you, please, say what the type of display is there?
tikhonte - 回复
If anybody needs a new battery, try this: 3.7V polymer lithium battery 503060 or 053060
The number means the dimensions (5 x 30 x 60mm) The first number is often in 1/10mm
You’d need to solder the original cable to the battery or cables though.
Maybe you want to leave a comment here if this was helpful: adahnsplace.blogspot.com
Endre Sutus - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 26
总计 4,369
