跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Commodore 1341 Joystick,请使用我们的维修手册
  1. Commodore 1341 Joystick Teardown, Commodore 1341 Joystick Teardown: 步骤 1 中的图像 1,1
    • Introduced in 1984, the Commodore 1341 joystick was designed for use with the Commodore range of computers including the Commodore 64, 128, VIC20 and Commodore Plus4.
    • This joystick connects to the retro computers using a 9 pin connection.
  2. Commodore 1341 Joystick Teardown: 步骤 2 中的图像 1,3 Commodore 1341 Joystick Teardown: 步骤 2 中的图像 2,3 Commodore 1341 Joystick Teardown: 步骤 2 中的图像 3,3
    • The joystick is held together by five phillips head screws. One screw is located on the handle and the remaining four are under the base.
    • Once the screws have been removed you can pry the case apart using a flat head screw driver. Just be careful with the base as it is spring loaded and it can fly apart quite easily.
  3. Commodore 1341 Joystick Teardown: 步骤 3 中的图像 1,3 Commodore 1341 Joystick Teardown: 步骤 3 中的图像 2,3 Commodore 1341 Joystick Teardown: 步骤 3 中的图像 3,3
    • You will need to desolder the fire button cables from the board.
    • Pry the case open but watch for the spring. There is also a rubber bung that sits beneath the black rocker shaft.
    • Desolder the cables from the main joystick board and remove all of the components.
    • Now you are ready to clean all of the joystick components and reassemble.
Andy Marsh
于04/24/10注册
118 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 7,009
