跳转到主内容
这个拆解是不是维修指南。 要维修你的的Christmas tree,请使用我们的维修手册
  1. Christmas Tree Teardown, Christmas Tree Teardown: 步骤 1 中的图像 1,1
    • The teardown shows a christmas tree Nano, but should you have a bigger - Classic one, you may follow these steps - upscaling everything.
  2. Christmas Tree Teardown: 步骤 2 中的图像 1,2 Christmas Tree Teardown: 步骤 2 中的图像 2,2
    • First order of business: presents!
    • Use caution and joy when opening your presents.
  3. Christmas Tree Teardown: 步骤 3 中的图像 1,2 Christmas Tree Teardown: 步骤 3 中的图像 2,2
    • Disconnect the power plug
    • Remove the power socket, should there be one on your tree.
  4. Christmas Tree Teardown: 步骤 4 中的图像 1,1
    • To remove the baubles, lift them gently and untangle the string from the branch.
  5. Christmas Tree Teardown: 步骤 5 中的图像 1,3 Christmas Tree Teardown: 步骤 5 中的图像 2,3 Christmas Tree Teardown: 步骤 5 中的图像 3,3
    • If you find a capacitor on your christmas tree, straighten its leads to detach it.
    • All discrete electronic elements should be removed in this manner.
  6. Christmas Tree Teardown: 步骤 6 中的图像 1,1
    • Protective hand-wear may come in handy.
  7. Christmas Tree Teardown: 步骤 7 中的图像 1,1
    • Remain gentle, even when an element is very difficult to untangle.
  8. Christmas Tree Teardown: 步骤 8 中的图像 1,2 Christmas Tree Teardown: 步骤 8 中的图像 2,2
    • To remove the top ornament, lift it upwards.
  9. Christmas Tree Teardown: 步骤 9 中的图像 1,1
    • Finally, remove the lights.
    • Begin with the light that was placed as the last. If you are uncertain, start from the topmost one.
  10. Christmas Tree Teardown: 步骤 10 中的图像 1,2 Christmas Tree Teardown: 步骤 10 中的图像 2,2
    • Before you run around barefoot in celebration, clean up.
    • Check amongst the floor sweepings for any surface mount components components which may have gone missing during assembly, and carefully put them aside
    • The christmas tree is disassembled!
    • Check whether your local council will take your old Christmas tree for recycling. Burning is not recommended on account of the CO2 emissions it would produce.
    • Thank you for reading, hope you are having a happy holiday.
    • Fix yourself a wonderful New Year in 2019!
baq
于10/14/09注册
305 声望
创作了3篇指南
一条评论
skuirel sed it good!
Kyle Wiens - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 8,650
