跳转到主内容
在此拆机指南中使用的工具
这个拆解是不是维修指南。 要维修你的的Charge 3,请使用我们的维修手册
  1. Remove both T3 screws Slide off the plastic piece by lifting out and then up Slide plastic and spring assembly off the rail
    • Remove both T3 screws
    • Slide off the plastic piece by lifting out and then up
    • Slide plastic and spring assembly off the rail
  2. Heat the glass screen with a blowdryer to soften the adhesives Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there Insert a razor blade between the glass and the body
    • Heat the glass screen with a blowdryer to soften the adhesives
    • Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there
    • Insert a razor blade between the glass and the body
    • Keep going around the rim of the display until loose
  3. This is how close those cables get to the edge underneath the Fitbit wording so be careful
    • This is how close those cables get to the edge underneath the Fitbit wording so be careful
  4. Lift display up gently The battery is attached with a little bit of adhesive so lift gently Remove battery connector
    • Lift display up gently
    • The battery is attached with a little bit of adhesive so lift gently
    • Remove battery connector
  5. Remove both T2 screws Liftoff metal shield
    • Remove both T2 screws
    • Liftoff metal shield
  6. Remove two T2 screws Remove T3 screw Liftoff metal shield
    • Remove two T2 screws
    • Remove T3 screw
  7. Liftoff both display connectors Liftoff both display connectors Liftoff both display connectors
    • Liftoff both display connectors
  8. Disconnect vibrator motor Disconnect heartrate and charging connector
    • Disconnect vibrator motor
    • Disconnect heartrate and charging connector
    • Remove altimeter
  9. Remove button assembly from case Remove vibrator motor Has a slight bit of adhesive and is magnetic to the case
    • Remove button assembly from case
    • Remove vibrator motor
    • Has a slight bit of adhesive and is magnetic to the case
  10. Remove motherboard It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
    • Remove motherboard
    • It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
Mathieu Mongeau
于2019年08月21日注册
351 信誉积分
创作了2篇指南
团队
Mat's Repairs Mat's Repairs 的会员
Business
1 名成员
创作了3篇指南
The tear down pictures are great, but in my Charge 3 I needed a T-1 and a T-2 driver
Julien Baldwin - 回复
Great job on this tear-down. Thank you, it really helped in my screen replacement.
AndyZ - 回复
This tear down was very easy to follow. The heart rate monitor was also sealed in with some adhesive for me too but a little heat gun took it right off. I had suspected water leaked in and that in fact was the culprit after inspecting the connection. corrosion all around the HR monitor.
Nick Herbert - 回复
添加评论
浏览统计数据:
过去的24小时: 8
过去的7天: 36
过去的30天: 189
总计 1,702
