跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Caterpillar B15,请使用我们的维修手册
  1. Caterpillar B15 Teardown, Caterpillar B15 Teardown: 步骤 1 中的图像 1,1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 Teardown: 步骤 2 中的图像 1,2 Caterpillar B15 Teardown: 步骤 2 中的图像 2,2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 Teardown: 步骤 3 中的图像 1,2 Caterpillar B15 Teardown: 步骤 3 中的图像 2,2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
  4. Caterpillar B15 Teardown: 步骤 4 中的图像 1,2 Caterpillar B15 Teardown: 步骤 4 中的图像 2,2
    • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
    • WARNING: Proceeding beyond this point will void the warranty for this device.
  5. Caterpillar B15 Teardown: 步骤 5 中的图像 1,1
    • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
  6. Caterpillar B15 Teardown: 步骤 6 中的图像 1,1
    • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
  7. Caterpillar B15 Teardown: 步骤 7 中的图像 1,1
    • There is one more Phillips screw remaining. It is located beneath the headphone cover.
  8. Caterpillar B15 Teardown: 步骤 8 中的图像 1,1
    • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
  9. Caterpillar B15 Teardown: 步骤 9 中的图像 1,1
    • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
  10. Caterpillar B15 Teardown: 步骤 10 中的图像 1,1
    • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
  11. Caterpillar B15 Teardown: 步骤 11 中的图像 1,1
    • Congratulations. You have successfully disassembled the Caterpillar B15.
Geoffrey Mosdell
于10/06/14注册
1,119 声望
创作了5篇指南
团队
USF Tampa, Team 4-7, Brown Fall 2014 USF Tampa, Team 4-7, Brown Fall 2014 的会员
USFT-BROWN-F14S4G7
4 名成员
创作了10篇指南
2条评论
Hi,
where can i buy T5 Torx screws for CAT B15 ?
Regards,
Laurent NOEL
Laurent NOEL - 回复
Any idea where I can get the rubber piece that covers the USB port? The one repair shop in the US wants about $200 for that repair.
John Nagle - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 11,463
