跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Casio Watch,请使用我们的维修手册
  1. Casio Digital Watch Teardown, Casio Digital Watch: 步骤 1 中的图像 1,1
    • This is a teardown of a Casio Digital Watch down to the internal circuitry.
    • You will need a small Phillips screwdriver for this teardown.
    Can we convert it into alarm clock with Big sound
    Ramesh marathe - 回复
  2. Casio Digital Watch Teardown, Remove the Case: 步骤 2 中的图像 1,1
    • Carefully remove the four screws on the backside of the watch.
    • You will need an extremely small screwdriver. A screwdriver to repair glasses would work.
  3. Casio Digital Watch Teardown, Gently Push out the Screen: 步骤 3 中的图像 1,2 Casio Digital Watch Teardown, Gently Push out the Screen: 步骤 3 中的图像 2,2
    • Press your fingers on the screen and remove the watch from its case.
    • Be sure to save the three buttons that control the watch
  4. Casio Digital Watch Teardown, Remove the Battery Holder: 步骤 4 中的图像 1,3 Casio Digital Watch Teardown, Remove the Battery Holder: 步骤 4 中的图像 2,3 Casio Digital Watch Teardown, Remove the Battery Holder: 步骤 4 中的图像 3,3
    • Remove the Battery Holder surrounding the circuitry of the watch by carefully pulling off each of the four clips.
  5. Casio Digital Watch Teardown, Remove the Battery: 步骤 5 中的图像 1,1
    • Remove the battery by pulling from the sides to unstick the adhesive.
  6. Casio Digital Watch Teardown, Detach the LCD: 步骤 6 中的图像 1,2 Casio Digital Watch Teardown, Detach the LCD: 步骤 6 中的图像 2,2
    • Remove the four plastic pins connecting the LCD and remove the LCD holder
  7. Casio Digital Watch Teardown, Teardown Complete: 步骤 7 中的图像 1,1
    • This reveals the internal circuitry of the watch, and the teardown is complete.
    Letters blinking problem .what is the solution
    purna Ganga - 回复
Cooper
于02/24/15注册
457 声望
创作了2篇指南
团队
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 的会员
CPSU-GREEN-W15S24G6
4 名成员
创作了15篇指南
2条评论
This is my Casio 5 alarm tear down. Can u tell me if this has anything on it that u guys didn't do. Please email me at dolphinzpride@gmail.com...
https://linksharing.samsungcloud.com/wQ5...
Skylar Miller - 回复
I have casio illuminator dual time watch, it was damaged outerward accidentally , but internal systems r safe. But now its digits r not displaying properly, sometimes digit parts r missing n sometimes fully 888888 r shown
Sarabjeet Singh - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 143
总计 12,690
